1 - 17 of 17 Posts
I will be building a downfiring ported Tempest X2 sub for my brother's bedroom and would appreciate suggestions/help on the design.
He has told me that he wants a downfiring sub which looks similar to his Yamaha YST-SW800. He wants the dimensions of the main enclosure to be around 600mmx600mmx600mm but he is willing to go to 700mmx700mmx700mm if it is worth it.
Just a quick sketch of what he wants (next to his old sub):
I have been doing some modeling with WinISD Pro but would you be able to give suggestions on the port design. He is really keen on a round port (or multiple ports) and I am willing to do bends but if it causes too many problems please give your ideas on a slot port. On slot ports, is it worth staying to a 5:1 ratio or less and would it make any difference if it was facing the wall (the sub will be diagonally in a corner so there is heaps of space behind it)? We were aiming at around a 16-18hz tune.
He would like a Yamaha P2500S amp which I believe should have plenty of power (1300W in 4 ohms bridged) can somone confirm this? or recommend another amp if it wont work. We will also need a high pass filter so could someone recommend one? We would probably set it at 19hz but feel free to adjust this to what will best suit the sub.
Ok thats a lot of questions :yikes: thanks in advance for help,
Sam T
Discussion Starter #9
Thanks for that, I came up with 4.715 ft^3 as the final volume, but do you know if there is a google sketchup model for the tempest so that I can work out the internal bracing more accurately. Also, what thickness MDF would you reccommend for various parts of the box?
Recheck your numbers, that seems small for some reason. If you do have 4.7 cu.ft. net volume then a 6" diameter port would be 36" long or you could use two 4" ports each being 33" long.
Building material should be 3/4".
The cabinet legs should be 4" high.
Contact members Moonfly and gperkins_1973, they might have a SketchUp file for the Tempest-X.
Discussion Starter #11
Are the air velocity values in WinISD a total across the ports or per port. e.g if it says 25m/s but I have two ports will it be 25m/s in each port or 12.5m/s?
Thanks,
Sam T
Discussion Starter #14
Ah thanks for that :T, I have tried many combinations of multiple ports only to get a high port velocity. Using Flare-it it shows plenty of headroom before chuffing occurs with a flared port.
Discussion Starter #15
Ok so this is what I have in WinISD:
The ports are 3.93" which is 100mm.
And Flare-it recommends a minimum flare radius of 36mm so we will probably go for around 40mm.
Does everything look OK?
Also, should I post in the amp section about the amp and highpass?
What high cut/low pass settings would you recommend?
Thanks for all the help,
Sam
Discussion Starter #16
If we went with a ep2000 amp instead of the yamaha one (saves $300 in Australia), and used a reckhorn b-2, what should we use for a high cut (lowpass filter) should we use? Also, do you use the LFE outputs or preamp out?
1 - 17 of 17 Posts
