61 - 80 of 241 Posts
Super Moderator
Alpine 12" Type R?
I saw Ricci post about them before but could not find enough info about them.
Does anyone have a file for the Latest tc sounds epic 12. I downloaded the one above and it seemed way off. When I try to enter my own parameters it ends up kind of goofy. Just want to check my work. Thanks
Way off from what? Measured specs? If so, please post them.
Anyway, I just went to PE and the published specs are the same as what's used to generate the existing file, i.e. instead of just inputting the basic T/S specs, the OP correctly inputted BL, Qms, Cms, Mms, Re, Dd, Xmax, Le, Pe and let WinISD calculate the rest.
GM
I was looking for the Dayton rss315hf-4 driver file. It looks like it was in post 6, but, i can't see it there now. Has it been moved somewhere?
Doesn't look that way to me. Regardless, unless the published specs have changed since 9.5.09............
RSS315HF-4
GM
dont suppose anyone could make files for the sundown audio. Specifically the SA 15 d2 and E15 d2. I tried to do them myself but couldnt get them to work right for some reason (kept giving errors)
