1 - 4 of 4 Posts
Does anyone know if either material is better? Both are matte white, Elite's "Max White" is listed as 1.1 gain and textured. The Accusreen is matte white(gain not listed) and textured. Both have black backing. Both are pulldown models. I was thinking about buying one, cutting off the material, and stapling to a wood frame I have. Do you think the material is pliable enough to allow me to get it tight enough on a wood frame, to staple on back? Thanks.
I have an Elite Sable Series fixed screen and am quite happy with it. From what I understand there is quite a bit of cost difference between the two. What's your application?
1 - 4 of 4 Posts
