1 - 12 of 12 Posts
I have a chance to pick up an elemental designs 16kv.2 driver in a 1.6 sealed box. It looks like the box was used in a car audio rig, not HT. I believe the eD stuff has a generally good reputation around here, and am wondering if this driver would be good in either a sealed or ported configuration for a budget, small space, not anywhere near reference levels type of HT set-up. :)
Do you have a WinISD file for it or the parameters? There was a D4 and a D2, which do you have?
The above is the only information I have on the driver - it is listed for sale locally, and I'm debating whether to grab it for a future project. Because we all know you can't have too many projects in the pipeline... :)
Mike,
Here you go.
16Kv.2 T/S Parameters
Spec 16Kv.2
Qts .32
Qms 3.60
Qes .35
Re 8.6
Vas (Liter) 162
Sd (cm^2) 545
Fs (Hz) 21.5
Bl 15
MMd 135.00
MMs 142.00
Xmax 15.1mm
Dimensions / Physical Information
Voice Coil 2.5" - (63.5 mm )
Spider Single 8" Progressive
Tinsels Woven
Mounting Depth 7.125" - ( 180 mm )
Mounting Diameter 14.00" - ( 356 mm)
Displacement .08cF
cheers
Graham
These as well which they state were from ED's website.
Specs: (From eD datasheet)
Continuous Power Handling: 650 Watts
Overall Outside Diameter : 15.375”
Mounting Diameter : 13.750“
Mounting Depth: 8.125”
Magnet Diameter : 7.20”
Voice Coil Size : 2.5
Thiele Small Parameters @ x=0
FS - 23.00Hz
Qe - .42
Qm - 3.0
Qts - .36
Vas - 254 Ltr
Sd - 0.0872 m^2
Re - 7.0 ohm
Sd - 0.0872 m^2 effective radius
Bl - 22.10 T*m
XMag 21.00MM
XSUS 26.00MM
XMax 21.00MM
Sealed Enclosure Range: 1.5-2.2 ft³
Ported Enclosure Range: 2.2-2.5 ft³
Driver Displacement: 0.08 ft³
cheers
Graham
I shot a note out to eD over the weekend, and received a response first thing this morning - nice! Here are the specs as they were sent to me:
Spec 16Kv.2
Qts - .32
Vas - 329L
Fs : 19 Hz
Re : 4.1
SPL : 90dB
Qes : .35
Qms : 3.6
BL : 15.9
Xmax : 16MM
Spider Single 8" Progressive Tinsels Woven
Displacement .08cF -
I tried to add a driver definition in WinISD, but my copy of the program decided today was a good day to get flaky. I can enter the params, but as soon as I try to model anything I get a floating point error. I'm not savvy enough to determine if this is a decent HT sub based on the parameters, but that Fs and Xmax get me kind of excited... :)
I tried entering the params as stated, but I think I might be doing something wrong. If I put that in WinISD I get a 10 cf boxed (sealed) with an f3 at 44 hz. Any thoughts from more experienced eyes?
Thanks Mike - from what I understand, it is currently in a 1.6 cf box but was used as part of a car audio system. Might take a swing at it in a sealed box, though even 18 x 18 x 18 is only 2.5 cf, and a 3 cf box might be larger than I really want for this project.
Any chance you can upload the driver file so I can play around with different models?
1 - 12 of 12 Posts
