What's the best way of wiring them: the VCs in series and the drivers in parallel, or the VCs in parallel and the drivers in series, or it doesn't matter?No... just cost and size. It limits you a little in terms of driver layout and what look you want to achieve. But no, two drivers per box mounted opposing has the advantage of canceling some vibration and as long as you can live with the box size, has no downside.
Kevin Haskins
Exodus Audio
It depends on the amp. What are you thinking of using for the amp?What's the best way of wiring them: the VCs in series and the drivers in parallel, or the VCs in parallel and the drivers in series, or it doesn't matter?
SM
The infamous and ubiquitous EP2500It depends on the amp. What are you thinking of using for the amp?
Kevin Haskins
Exodus Audio
To verify: You mean each driver gets it's own channel, or run a pair of EP2500s bridged with each driver getting it's own amp.The new ones are single 4-ohm coils. Just use one per channel of the EP2500.
A pair of the EP2500s would not be overkill.
Kevin Haskins
Exodus Audio
I plan to have two duals up front near the corners and two singles on in each of the sidewalls. I have a total of 4 EP2500s. The room is 6000 cf. I doubt I'll need to run them very hard. :bigsmile:
