21 - 33 of 33 Posts
Discussion Starter #22
I picked up the primer for it today. Still need to do one more final power sand on it thought. Then prime and I am going with black but undecided on just black paint or duratex.
That primer looks like it did a good job covering. Are you happy with the primer? I ask because we are always/still looking for a good high-build primer that actually covers like they claim it does.
Discussion Starter #25
I think it did a good job. Even though I feel the sides are flat/even as I could get them sanding I can still see the joints. I may put a few more coats on before final paint. I used Zinsser 1-gal. White PrimeCoat 2 Water Interior Primer and Sealer and had them add gray tint to it.
Discussion Starter #29
There are a few small flaws in my painting with duratex but nothing major. I think part of it was I started off with a smaller roller as I wanted more control(3") but finished the last coat with 6" which worked fine.
Both boxes are put together and tested off old amp just a check - does it work? and yes both of them are working. They make my current 12" look small. Need to take more pics probably tonight or tomorrow.
Super Moderator
Well the finish looks great to me in the pics.:T
Discussion Starter #33
Thanks
No tweaking yet. Listened to some tunes and now the boys are watching Legend of the Guardians: The Owls of Ga'Hoole .
21 - 33 of 33 Posts
