1 - 10 of 10 Posts
I am thinking of adding an Energy S10.3 to my 5.1 set up. I currently have and plan to keep a Mirage Omni-S12. These two subs are not the same, but like first cousins. I would place the Energy in the corner of the opposite side of the room that the Mirage is on. The Mirage is on the front wall between my center and right main. So the Energy would be by the right surround and nearfield.
Would the addition of the Energy be beneficial to my set up? Would I have any potiential phase problems with this placement. I have the Mirage at "0" on the phase switch. Would the Energy have to be at "180"? Or would I have wait and see once its in place.
Thanks
Well difference is just 100RMS (Omni 300RMS and Energy 200RMS, and 2Hz on the FR) ... but if you can, get another Omni :yes:
My suggestion, place the energy in the left side if you can (that's the way I have my subs) ... or if you want to do it right: do the crawling test to place the first sub and then add the other to complement the set up ..:yes:
Your best option here is to download REW and do some test to see which set up work better :yes:
The left side of what?
My mistake ... left side of back wall (near left surround, so they'll be diagonally) ... you can also try the left front.:yes:
You need to experiment to find the best placement .. there's a study that JBL did (let me see if I can find it) ... I think the best placement where one on each corner, or one in the middle of each wall :yes:
I want more output and the ability to go lower. The Mirage is on 87db @ 20HZ, although the average is 109db between 20-62HZ. That is why I am leaning towards Epik now. They are reportedly good with music as well. AV123's offering fits the bill as well.
I am somewhat in a similar quandary. I have ML Descent i in a 22"x13"x10" room. I have a big null at the main seating position at 40Hz which is not corrected by moving the sub. I am planning to add another small sub diagonally opposite to ML. The smaller sub goes down to 25Hz. To avoid odd interaction between the two subs I am planning to use the crossover in the receiver for the smaller sub & use the crossover in ML for Descent i. This way the smaller sub will work from crossover point in receiver to approx 30Hz & below 30Hz ML will take over. What do you guys think with this kind of setup. Need input all you subwoofer guru's.
1 - 10 of 10 Posts
