Hi all
I am hoping you can help. My 1 year old somehow got hold of the remote control for this unit while watching a DVD. We are now unable to use any buttons! When we press anything we get the message "Audio Sync" in the bottom left hand corner of the display. The DVD plays as normal but we are quite literally unable to use the remote - even the power button results in this message. Pressing up and down on the volume control button results in the machine cycling through what I presume to be the two sound settings (5.1 etc) but this is all we can do. We can't even eject or change the volume!
I have had a look in the instruction manual and online and can find no solution to our problem. We have turned the unit off and on again, switched it off at the mains but nothing has worked.
Are you able to help us please? Any insight would be greatly appreciated.
Many thanks
Many thanks
