1 - 9 of 9 Posts
Just purchased the Dy's focus 110A's. They will be here on Wednesday. I will be using my Chordette Gem Dac to stream my music from my Mac after I sign up for iTune Match. I will take my time listening to these Moniters with the Chordette before making a final decision for another DAC. Bel Canto 2.5 is one I am considering. However having the Chordeete leaves me some space to breathe a bit b/c I am also in the market to buy the Marantz 8801. If that is what I decide the Dac will come in time.
I had a pair of those for a while connnected directly to a SqueezeBox Touch. An amazing compact system.
Thanks Kal
I am looking forward to reviewing my music again.
Unfortunately it looks as though I will have to purchase a NEW DAC. The Chordette Gem that I have has no volume control and of course I will need one. At present it is connected to my processor via Bluetooth.
I was hoping to hold off a little awhile and invest in the Marantz 8801 instead.
Time to break up the piggy-bank
Kal
If I got the 8801 could I connect the 110's independently of my 804S speaker.
2zones? One for 7.1 and the other for2channel stereo?
If so, is the Dac in the 8801 good enough for the 110's?
Kal
I believe that you can do that but I have no experience with anything other than a main zone. Yes, the DAC is good enough.
Thanks Kal.
I will check with a local audio dealer in my area if no-one is SURE I can use a second zone for my 110's.
I have the question posted on a couple of forums other than this one.
One last question if you do not nine. I know you said the DAC in the 8801 is good enough but does it out perform the Chordette Gem. The Gem is about three years old so I am guessing if it does.
Thanks Kal.
I have no idea. Never used the Gem.
Well I made a decision....thank you, thank you.
It was tuff one to make when you want everything and you are on a budget.
I picked up a pair of the Dynaudio Focus 110A's on line from Audiogon. Dedicated Audio from Scottsdale Arizona a family ran business. They were very helpful. I also purchased the stands for the 110s.
Just last week I was in Delaware and I decided to demo at home the Bryston BDA1 DAC. I still have the unit and probably will keep it. The store is letting it go for $1500.00 to make way for the new Bryston BDA2. Not much difference I am told.
I am reliving my music.
Needless to say I am very happy.
Thanks for getting back to us, Frank.
I love the Dynaudio sound, and Bryston makes top notch gear, with digital warranties of 5 years and analog warranties of 20 years!
Happy listening. :bigsmile:
1 - 9 of 9 Posts
