I want to build my first ever sub-woofer(actually first ever anything), using Shiva X. I was reading the
"shiva_app.pdf"
and I am interested in "**6.35 Cubic Feet (180L) tuned to 18Hz with two 4” flared ports"
Can some one give me the enclosure design for the above.
If someone has a better design for this setup , please post. Which amp do I need to use 500 Bash amp or 500 watt dayton amp?
I have zero carpentry skills, hence I will be taking the design to lowes or some cabinet maker which will cut the enclosure as per the design. Then I can assemble it. Thanks.
Dev
"shiva_app.pdf"
Dev
