21 - 26 of 26 Posts
Discussion Starter · #21 ·
hi,
it looks like i can't get the ed1300 anymore.. I was looking at the yamaha p series
http://www.yamahaproaudio.com/downloads/data_sheets/power_amps/P_Series_datasheet.pdf
I don't understand this: Frequency Response 8Ω, Po=1W,HPF=OFF MAX +0.5dB, TYP 0dB, MIN –1dB f=20Hz-50kHz
does this mean it will not produce frequencies below 20 hz? Should i be concerned? Since this has a hpf and a lpf, i suppose i don't need a "eq" like the Reckhorn B1?
Mike will the 24" cube on the creativesound.ca site..http://creativesound.ca/pdf/Quartet15_Subwoofer_Kit.pdf be on par with the svs pb13-ultra? I would like something better than the svs so i don't have to upgrade in 3-5 years.
Thanks!
Discussion Starter · #23 ·
Why?
The kit will exceed a pb13-ultra according to a comparison of the graphs.
CSS doesn't carry it anymore. And that's pretty much the only place in canada where I can find it.
Here's another question. If i build the sub with the 2 PRs, and put it in the corner, how will that affect the sound? it will be beside the axiom m80s.
The amp is out of stock until March/ April according to the CSS website. You could ask E.D. to ship you one by USPS to save on brokerage charges.
As long as you leave some room between the PR and the wall you'll be fine. Angling the cabinet at a 45 degree angle to the corner would work.
21 - 26 of 26 Posts
