I can pick this up used locally for $75. http://www.edesignaudio.com/product_info.php?t=2&products_id=36 Here are the specifications:
Qts: .36
Qes: .42
Qms: 3.0
Fs: 23.00Hz
Re: 7.0
Vas: 254L
Mms: 202.0g
Bl: 22.10T*m
SPL: 91dB
Sd: 872cm²
Xmax: 21.0mm
Voice Coil: 62.5mm
Would this subwoofer work well in a sonotube setup? Are there new subwoofers that can be had for under $150 that would work just as well? I was thinking about using an 18" sonotube with about 200l of volume tuned to 18hz or so.
Qts: .36
Qes: .42
Qms: 3.0
Fs: 23.00Hz
Re: 7.0
Vas: 254L
Mms: 202.0g
Bl: 22.10T*m
SPL: 91dB
Sd: 872cm²
Xmax: 21.0mm
Voice Coil: 62.5mm
