1 - 3 of 3 Posts
I am not sure this is the right Forum to ask for help re Xover.
I have been using the Energy EAC Crossover for many months. This morning , I decided to bypass the Xover so I made some interconnect changes. After testing my speakers without Xover , I reconnected the Xover and now suddenly I get a loud 120Hz hum. With the Xover unit out of the loop and Preamp connected to power amp , I get no hum. As soon as I connect the Xover output to the power amp the hum reappears. Any idea what has happened? I have not changed any of the mains power connection so it cant be ground loop.
If power bug ( AC 16V) is removed from the Xover unit there is no hum even with Power amp connected. Hum immediately appears when power is applied to Xover with no inputs connected. ( ie just Xover and Poweramp)
I opened the Xover unit and resoldered the input /output RCA connectors to the PS Bd , thinking it could be a bad solder joint but unfortunately this did not solve the problem.
Finally I probed the unit with an Oscilloscope and noticed quite a ripple on the + Line after the first rectifiier cap ( 2200UF, 25V) . Could this be the culprit? I wonder how often a Lytic Cap goes bad.
Any other ideas?
Tks
Replacing filter cap reduced the ripple but did not solve the problem. After looking very closely at the I/O RCA block, I found that the output RCA connectors did not have a ground connection to the PC BD ( which caused the hum ) Resoldering the pin did not fix the problem because I think the ground connection was broken between the pin and the RCA Connector grounds internally ( probably over stressed when plugging and unplugging the interconnects.) Fortunately there was another place between the L/R output that I can solder a piece of hookup wire and then ground that to the PC ground . The access point between the output RCA connectors saved me having to remove the whole block ( nine connections)
Now all is fine :)
Thanks. I think I will increase the filter cap to 3300UF or higher to reduce the ripple a bit more.
1 - 3 of 3 Posts
