Status
Not open for further replies.
1 - 4 of 4 Posts
Since buying my A5-350, I have built two 18" sonotube subs (with eD drivers.) I haven't used my A5-350 much at all since building the sonos. Now that I am finishing my basement and the sonos are going to go into a sealed room, I definitely won't need the A5-350 any longer. It works great, no problems whatsoever and it has the newer version of the LT/550 amp. The sub is just under 2 years old and the amp was upgraded to the newer model a little less than one year ago. Still has 3 years left on the 5 year warranty.
Louisville, KY area. Pickup only. Will possibly meet half way if coming from far away.
New $800
Refurbished B-stock from ED with the smaller 350w amp $575
I'd like to get $500 for this and think it is a reasonable price.
I'm local and interested. Is this the new version with front-firing woofer or the older down-firing version? Are you the original owner and if so when did you buy it?
Thanks,
Sam
1 - 4 of 4 Posts
Status
