I'm admittedly new to calibration and room measurement, so I hope I'm not making any major blunders here.
I'm getting started on REW, mainly to fine tune my sub crossover and phase, as well as tweak speaker placement for my two-channel music system.
I picked up a Dayton EMM-6 for next to nothing (restock) at partsexpress. I've got two preamps I've demoed it with: a Focusrite Scarlett Solo and a Tascam US-4x4. The Tascam has a bit more headroom on the pre's, I believe, though I've been using the Focusrite because it has RCA outputs - minimizing the number of adapters I have to use.
I'm aware that the EMM-6, being a small condenser, possesses higher self-noise than most of the mics I use for music. I'm also aware that it's a low sensitivity mic. But the noise floor on this thing seems absurd. Without another SPL meter, I'm unable to state what my actual source level is, but at a comfortable/low listening volume, the sound from the speakers is almost undifferentiable from the self-noise. Spoken words right next to the mic are audible, but remain awash in static. With the Focusrite gain nearly maxed out, I get self noise of -20dB. Snapping my fingers or speaking right next to the mic shows my levels creep up to -16dB or so.
I'm concerned I'm not going to get any usable room response data without cranking the speakers beyond what I'm confortable with. I know I don't need loud signals for calibration (though I imagine it helps), but will a VERY persistent self-noise throw it off?
So my primary questions are:
- Is there a better way that I can assess the severity / effect of the self noise of this mic?
- Is it conceivable that I've got a dud mic? It was a restocked item, but it didn't appear to be used.
- Am I unduly worried about the effect of the self-noise? Is it less of an issue than I'm making it out to be?
