Hello,
Curious if someone could figure what the tuning is of this enclosure. Cabinet has a net volume of 2.61297 ft^3, the port configuration is as follows: slot port 2.75"X5.825"X12.750", then 2.000" from back of slot wall there is a 4.000" dia.X12.000" long tube. The back of the slot port is not open to cabinet, just a continuation of the round port. Slot is foward facing and round port is perpendicular to the slot. I know how to figure one or the other, but not in a combined configuration. Any help would be greatly appreciated.
Have you got some pictures of it you can put up, just to be sure we know exactly how this is configured.
Sorry my photo and sketch are not uploading. Slot port is 2.75 tall X 5.825 wide X 12.750 Long. Round port is 4.000 inside diameter and 12.000 long. Round port is 2.000" from back of wall. Overall pipe diameter is 4.500" it is basically a slot port, just not open to the back of cabinet and has a round port coming up from the bottom of slot. I will try get a picture up later tonight. Thanks.
