I have an energy s8.3 plate amplifier (100 watts rms).
Long story short - used a 4ohm sub, the amp turned out to be 8ohm stable - fuse blew.
Replaced the fuse, and as soon as I plugged it in, fuse immediately blew again (with no signal going to the amp). Same thing happened once more (third time's the charm, right?). Replaced with a fuse double the strength to try and determine where the short was happening...
This time, fuse didn't blow, but smoke started coming out near one of the large capacitors. Upon further inspection, the ceramic resistor near the cap was glowing RED hot, and smouldering that yellow glue stuff near the cap.
I would like to repair this amp as I can use it to build a budget subwoofer for my office, but I have no idea what the problem is. Could it be that I fried the cap, and the resistor is getting too much voltage? I have some experience with soldering on new caps, and I have a multimeter, but that's as far as my knowledge goes.
Any ideas what I can do to test this amp and figure out what to replace?
The image attached shows the resistor that is smoking right next to the left cap. You can see where the glue has been burned black.
Thanks folks.
Thanks folks.
