1 - 3 of 3 Posts
Good afternoon
Anyone could help me and point me in the right direction
I am looking for replacement screws for the EP4000 chassis, I called a few Behringer dealer none has that listed as a part , went to my local reno depot did not have that kind of screws
Thank you for your help
Alain
Are you talking about the screws holding the cover on? They should be small sheet-metal screws, nothing special, that you can get at any hardware store. If they are machine threaded, same thing, they’re probably a common small metric size.
Hi Wayne
Yes they are the one i am looking for the 4 small one on the top plus some on the side
I will go to another hardware store tomorrow morning they might be of better assistance
Thanks for your help
1 - 3 of 3 Posts
