Hi, I'm new to the forum and will spend most of the day reading all the fine info on this forum!!
Just picked up a Epson HC 8350 projector. I'll be putting it in our big 60'x40' garage - Man Cave
- It's heated and we have a ton of sporting even parties out there. Looking for info to build a 200" screen ( 98"x173").
Question: what will be the best material for the screen - MDF, Drywall, Paneling
and which paint to go with.
Thanks!!
Epson HC 8350
Projection System: Epson 3LCD, 3-chip optical engine
Color Brightness (Color Light Output): 2000 lumens1
White Brightness (White Light Output): 2000 lumens1
Contrast Ratio: Up to 50,000:1
Color Reproduction: Full-color (1.07 billion colors)
Color Processing: Full 10-bit
Type: Manual zoom / Manual focus
F-number: 2.0 – 3.17
Focal Length: 22.5 mm – 47.2 mm, Widescreen image size (projected distance),
100" diagonal (wide: 9.8' – tele: 20.9')
Zoom Ratio: Manual 2.1x
Thanks!!
Epson HC 8350
