EQ with FBQ 1000 & AUDYSSEY
1291 Views 2 Replies 2 Participants Last post by  soco
I have an old ONKYO av, i left off two channels of the auto cal, center and sub(sub no diferrence with audyssey)
I have now two filters in the sub channel, i will upload the results because i have stuck ...
I also recal. the distance fοr the sub .
Text Green Line Blue Pattern
Text Green White Line Pattern
Text White Line Pattern Plot
Text Green Line Font Pattern
My coach is also stuck :D to the wall , all the mic positions ''back'' are of the 3 seats when i seat normally, at about 1,5 meter(5 feet) area and the ''front'' are also the same area at about one foot front and less than a foot lower..
I must tell you that i have also place some pillows at the wall, behind me at the head hight and an absorption panel.
1)first of all the audition make thinks much better (i had i peak as this at the 22hz )
2)i had and also have a problem with the '' bass feeling '', i will explain what i mean.
I dont have a chest hit at the explosion scenes , also on music scenes with drums like ''whiplash'' i dont feel in my body that kick drum.
3)my center is ; http://www.m-audio.com/products/view/m3-8#.VoUawLaLSM8
4)my av is http://www.onkyousa.com/Products/model.php?m=TX-SR805&class=Receiver
5) sub is http://www.earthquakesound.com/index.php/en/browse-products/item/supernova-mkv-15piano
I leave this year with sound problems , but i believe with good will each obstacle disappears.
Health and Peace to all of you!!
1 - 3 of 3 Posts
You’ll probably need at least a couple more filters to smooth things out with the sub. That “chest hit” thing is in the 60-80 Hz range, and right now that range is overwhelmed by the >40 Hz range. I’d suggest working on a house curve for the sub between ~100 to 25-30 Hz, and shelve below that point.
Happy New Year ! Peace,Joy,Love,Good Health and better hearing!!
I boost 7db at the bass eq of the av at center channel, so to lift the 60-100(i know bass boost is over that about>200 but i was desperate) and run the audyssey to all channels except subs.
c (center position)cf(center front ~ a foot)
I also have all channels cut at 80hz , but look what happened.
1)i covered the overwhelmed problem somewhat but it still exists (no chesty hit)
2)i destroyed the mids, voices became terrible dirty with extra bass
3)the 45-50 hz boost 5 db and i forced the filter there with extra 12 db down!
4)the audyssey i think made everything worst, unfortunately this time was with the boost bass eq , and i didnt check it without that, but look at the measurements at the 1khz-20khz .. what is this autocal for? good or bad?:dontknow:
Only the 4-5th graph is without audyssey+boost bass the center and before the extra low filters
Text Green Blue Line Plot
Text Blue Line Green Plot
Text Line Pattern Plot Design
Text Line Blue Plot Pattern
Text Line Plot Wave Pattern
1 - 3 of 3 Posts
