1 - 2 of 2 Posts
Error message (FIXED)
Hello folks,
I have run REW many times before, and I am fairly proficient, but now when I try to run REW I get this error message:
ERROR #10: A Java Runtime Environment for 'roomeqwizard.exe' cannot be found.
A Java Runtime Environment needs to be installed before 'Room EQ Wizard' can be run.
I have downloaded Java and the runtime environment 64 bit numerous times, but I keep getting the same error. What do I do to fix this?
Thanks
Discussion Starter · #2 ·
Problem fixed after 2 days of working at it.
REW didn't recognize Java.
Windows did not remove all Java components so I had to use the Java uninstaller instead on the Java website.
When I tried to reinstall Java, the files were still corrupted.
I finally found and used the offline Java installer, which got Java installed correctly.
I had to install both Java 32 and 64 bit versions.
Now REW works fine.
1 - 2 of 2 Posts
