1 - 5 of 5 Posts
G
hello
i try to use REW but I've got a probleme, every graphs are falling at 12khz. I've use 3 different microphone, 2 different preamp, 2 different sound card,,,,,but always the same probleme. i don't understand where can be the probleme.
I need help
Not enough information. Can you post a graph so we can see what you are referring to?
Also post a graph of your soundcard calibration file.
What microphone and preamp are you using?
Also explain what and where you are measuring. Is it near field or listening position.....
ok I hope this helps
Again, you haven't provided any information.
What are we looking at? Looks like peaks at 4K-8K.
Explain each line.
Normally all measurements are taken with a calibration level of 75dB.
Use a vertical scale of 45dB-105dB.
hello
I agree, you need to tell us what microphones you are using as well as what pre-amp and sound card.
Without this information its tough to help you much more.
1 - 5 of 5 Posts
