1 - 20 of 28 Posts
there is some one selling a Exodus Audio Maelstrom Gen. II 18 dual 2 ohm sub by me and i a few questions about that sub. first has anyone else put one of these in a vehicle cause most use it for home audio. second what would be a recommended box in a 01 tahoe, sealed or ported and what cuft? i have a jl audio 1000/1 sub amp to power the sub will this be ok? i appriciate any help. i have 3 jl 12 w3v3s in the truck now and it just doesnt do the lows like i want. will the maelstrom blow the 12s out the water or what?
the 12s are the w3v3 version in a 7cuft ported box after displacement tuned to around 35 hz. the port is 90sq in and 15 inches deep
Discussion Starter #8
Peak Power Handling: 1000 Watts
RMS Power Range : 75-500 Watts
Impedance: 8 Ohm
Diameter: 12 Inch
Sensitivity: 87.15 dB
DMA-optimized, long linear excursion capability to virtually eliminate distortion and increase sound output
Perform outstanding in compact sealed or ported enclosures
DMA (Dynamic Motor Analysis) modeling to deliver unsurpassed dynamic stability and low-distortion operation within intended power range
Mineral-filled polypropylene upper cone with a metallic JL Audio medallion logo gives the W3's a whole new, classy and sophisticated look
Vented Reinforcement Collar
Insert Molded Suspension / Coil / Terminal Sub-Assembly
Customizable Trim Ring
Elevated Frame-Cooling
Floating Cone Attach Method
Surround Stress-Relief
Free Air Resonance (Fs): 26.72 Hz
Electrical "Q" (Qes): 0.472
Mechanical "Q" (Qms): 7.572
Total Speaker "Q" (Qts): 0.444
Equivalent Compliance (Vas): 2.844 cu. ft. / 80.54 liters
One-Way, Linear Excursion (Xmax): 0.510 in. / 13.0 mm
Reference Efficiency (no): 0.313%
Efficiency (1W/1m): 87.15 dB SPL
Effective Piston Area (Sd): 80.600 sq. in. / 0.0520 sq. m.
DC Resistance (Re): 3.563 ohm
Nominal Impedance (Znom): 4 ohm
Thermal Power Handling (Pt): 300W
Driver Displacement: 0.071 cu. ft. / 2.01 liters
Net Weight: 14.50 lbs. / 6.58 kg
Priced individually
12W3V3D8 - JL Audio 12" 600 Watt 8 Ohm SubwooferRelated Accessories
Here's a start. Green is the Maelstrom in the same size box as you have, since it's 4 ohm your amp will provide 500 watts. No subsonic filter is required. Yellow is what you currently have with your JL's, the amp is putting out about 800 watts and a subsonic filter at 25 hz. The JL's would do better in a bigger box with this amp if that's an option.
Discussion Starter #14
thats pretty cool. the amp does 1000 at 1.5-4 ohms so it would be 1000 at 4 ohms does that change anything? also what port size for the 18? and thanks for doing this.
Discussion Starter #15
so what size box would you suggest for the 12s? i really want them to drop but they are 12s and you can only go so low thats why i kinda wanted the 18 so it would hit low
Discussion Starter #19
alright thanks. whats the program your working with and where can i get it? id like to mess around with different box sizes. but hey thanks alot for your time i gotta hit the hey.
1 - 20 of 28 Posts
