1 - 7 of 7 Posts
Hello
I have three Exodus LCR speakers and now have a bad crossover in one of them. Does anyone have a Mid/Tweeter crossover they would like to sell? I am having problems with the Mid section of the crossover causing my reciever to go into protection mode all the time during certain parts of a movie. If I disconnect the mid speaker and play the same part of the movie all works great. I did try changing out the mid speaker with another one but the problem continues so it looks like there is an issue with the crossover.
Thanks Rick
· Elite Shackster , HTS Moderator Emeritus
Protection mode sounds like a short. That would be the first thing I try to look at on the crossover board.
My next thought would be a capacitor gone bad. If they arc inside that can set up a short as well.
Although a short would be present even when the driver was removed. When you say you removed the mid driver, did you just remove the driver itself, or the whole crossover + driver?
If it's only shorting when the driver is in place, you may have a bad driver. Check the DC resistance on it and report back.
good luck.
Here is a little info. First the speaker only shorts out my receiver during certain parts of a movie. It is consistant when it happens during these parts. I did try switching out my Mid driver with one from another speaker that I have no issues with and the same thing continue to happen. Now when I disconnect the mid driver (remove the positive side off the speaker) I can play the same movie over and over and the receiver never shorts out. Thus this is why I think it has to do with something on the crossover.
Rick
1 - 7 of 7 Posts
