1 - 5 of 5 Posts
Hello everyone!
First of all, thank you to the makers of REW. It is truly an amazing piece of software, and I have only begun scraping on the surface of what it's capable of. So, thank you! :clap:
I have bought a miniDSP through a group purchase here in Sweden. Last night I found that the biquad file that REW created used commas as decimal separator (which is what we use here in Sweden), instead of period, which is what the miniDSP expects.
I tried changing the localization settings in Windows (XP), but nothing helped.
Is there a Java setting somewhere, as it seems REW does not take into account what localization I have set.
Excellent. Thank you for clearing that up.
In the meanwhile, I can search and replace all commas with period, and afterwords search and replace all periods+CRLF with comma+CRLF.
Thanks John,
I tried your suggestion, but unfortunately it didn't bite.
No worries though. I have the search-and-replace workaround until you get to it. Thanks in advance!
1 - 5 of 5 Posts
