1 - 20 of 22 Posts
hellu!
ok just bought this fbq2496..
and have been :reading: about the hum issues....
how loud is the hum, if someone still have that issue?..is it clearly heard ?
i have a very low humming noise coming out from sub...when i really listen after hum...
and now that i know that the hum is there it annoys me..:wits-end:
i already tried to shift power from an grounded outlet vs a non-grounded one..no difference...
but when i pull the rca coming from receiver..the hum is gone...
have any of you tried or/ whould something like this be helpful:
http://www.neutrik.com/fl/en/audio/210_1331174287/NA2M-D0B-TX_detail.aspx
btw....my connection is xlr's at fbq and then to rca @ amp....
thanks/H the newbie... :p
So you have RCA out at the receiver and XLR in at the BFD. Can you tell us the configuration of the cable you're using?
hi! ok...you are awake over there... :)
i'm using unbalanced @ the xlr's (pin 1+3 bridged)
any concerns with that?
/H
No hum with my FBQ2496, and I am using RCA cables only.
Tim
:drive:
Discussion Starter #6
I would remove the pin-1 to pin-3 bridge, leaving pin-1 open.
ok...will try that tomorrow.. perhaps it's that easy... :)
hmmm what connection whould that be?..some sort of semi un/balalanced xlr?... :heehee:
well...only time will tell....tomorrow..or later today (it's 2.30 am here now)....i was thinking of something like that before........let's all put our hands together and.. :praying:
regards/mrH
Discussion Starter #7
Tim
:drive:
ok...rca to 1/4 jack youmean? or have you modded the fbq to rca?.... :)
there are lucky guys in this world....with life sooo easy.....i'm not one of them though... :sob: ;)
keep on rocki'n /H
Yep, I'm using 1/4" to RCA adapters in the jacks on the FBQ.
Discussion Starter #9
ok...
tried the xlr/pin 1 open thing..but hum is still there:sad2:
also tried couple of complete cables with 1/4 to rca...same thing there....hmm:dontknow:
/H
ok...
Well, that indicates the noise is resident on the signal line and it's not a ground loop issue with the FBQ. This is backed up by the fact that an ungrounded outlet didn't clear the problem.
This would also indicate that the problem would still exist if you removed the FBQ and connected directly from the reciever to the sub.
Is that true?
Discussion Starter #14
i'm gonna try later to take power from same ac-outlet to receiver ,fbq and sub to see if it makes any difference.....
/H
Does something/parameter inside the bfd need shutting down/turning off......did i read somewahere that there is a noise reduction file/download file etc.
Discussion Starter #17
I may have an answer but its from the AVforums....am i ok to post it for you or not.....it could be from here any vays.
post link?
or post here or send PM to me... :)
regards/H
Discussion Starter #19
I can't seem to find it now but how many filters have you got in place...........if there has been two many filters being used apparently it results in a very high gain and there for hum or hissing noises as a result.
haven't gotten that far yet in my calibrations..:bigsmile:
so the answer is: i use 0 filters.... :)
/H
Right gotcha.......so try the Art cleanboxII and see how you do i've just ordered one because knowing my luck it'll huumm along also.....
1 - 20 of 22 Posts
