1 - 3 of 3 Posts
Hi,
I am just starting to use REW for live sound public address sytem EQ.
One feature that Smaart has the REW does not is the ability to display the frequency of the peak levels in the RTA this would be done in real time with the frequency identified being shown on the peak itself.
This allows a live sound engineer to quickly see the exact frequency of a feedback signal so that it can be quickly EQ'ed out either with a parametric of 31band EQ
If the THD button is selected the frequency of the peak in the input is shown as the fundamental. The harmonic info would be nonsense but at least the peak is shown. I'll add a better way to show the peak to the todo list.
Hi there,
I am really pleased & surprised to have a quick personal response from your good self!
I will try to THD setting, I really appreciate that you are considering adding the feature in the future.
1 - 3 of 3 Posts
