1 - 12 of 12 Posts
For some reason I am having a of a time with feedback as soon as I connect the Galaxy CM-140 using Turtle Beach Amigo II USB sound card.
I have tried 2 different computers with same results.
I have Calibrated the Soundcard and the graph look good.
I go to Check levels and I can not even get to 75 db and feedback occurs.
I have been doing some reading and trying to figure this out but can't get pasted it.
What is happening exactly that you are describing as feedback? On any computer, you want to be sure that mic input playback is muted...
That's the problem, it's not giving me that option, it cannot
Be muted. I am running XP.
Pretty much all the external sound cards listed aren't
Manufactured anymore.
Is there an external sound card that's still in production
Today that definately works?
You're looking for something similar to the above picture ( ie; make sure that "Listen To This Device" is left un-checked ) .
The problem you may have is finding which tab "Turtle Beach" has placed this option into and what have they named it .
The "play-through/monitor" option will be there ( in some form ), you just have to find it .
:sn:
:sn:
Thanks for the help, I have searched around XP and I cannot find any settings for that, I think the Turtle Beach Amigo II doesn't allow to adjust for that setting.
On the playback mixer settings ('Speaker') check under Options -> Preferences that all the available volume controls are selected for display, there can be an "Input Monitor" volume control that is not displayed unless you select it in the preferences:
That's the problem, I only have the first 4 options
You have checked, there is no other options in that
Window under TurtleBeach. Under the recorder settings
There is only mic.
It's definately the sound card options problem.
I have a SoundBlaster sound card on the way.
The Turtle Beach Audio Advantage Amigo II will definately
Not work.
Just to clear this thread up the TurtleBeach Audio Advantage Amigo II did not give me the option to mute the playback.
I purchased the SoundBlaster X-Fi Surround 5.1 Pro which did work fine. Just had to load their software and disable any surround modes and everything worked out great.
Thanks for all the help.
1 - 12 of 12 Posts
