1 - 7 of 7 Posts
I am trying to input two amplifiers (separate rooms) from the Sky plus optical output. Both work individually, so the signal's fine. I've tried a 'Y splitter', but guess I understood it's function the wrong way round as neither worked when I tried it.
As I understand it 'Optic Switches' direct the beam so that only one receiver can be fed at a time, not both simultaneously?
Is this correct, or is there a way so both can be utilised at the same time?
Any ideas or advice gratefully received.
dunno dude... good question. I've never seen an optical splitter for sure.
good luck man and welcome to the forums here. I hope someone can help you.
What you need is a distribution amplifier this splits the signal and amplifies it so that the each device receives a full power signal. When you use a splitter each device receives half the signal which may not be enough to power the end device.
The concept is explained here:
http://www.multidyne.com/blog/2009/02/optical-repeaters-and-distribution-amplifiers/
I found this one at Markertek but have no experience with it. They can probably help you out if you give them a call.
http://www.markertek.com/Routers-Switchers-DA's/Video-Distribution/TLDA-1.xhtml
Good luck.
1 - 7 of 7 Posts
