Hey guys,
I finally got the means :spend: to put together my build i Got the 18 In Fi Q (dual 2 ohm, loaded) and a Behringer Europower ep4000
Although im lost for a box build
I thinking Mdf 3/4 or 1 in i cant decide ive been told 3/4 is fine cheaper and more easily obtained at a HD or Lowes
I was thinking sealed Cube or Rectangle box
Ported or Sealed ive go the power for a really nice Sealed i herd the Sq is wonderful But i do want it to get loud!!! :hsd: :yikes:
Use is primarily music but for movies or HT too, but mostly for playing music and Bass Guitar(if i can?):dontknow:
and screws counter sinking all these i need some advice.:huh: :dumbcrazy: im kinda lost there
Also Veneer i was thinking something cheep with just glue and iron on, but if too much cost im going to just stain and put protective coating
Also FIBERFIL Lost there i dont know how much and how to put in
Bracing i Herd that was important and Graham did a great job i was thinking a box like his but cut in half???
here a few design some fellow shacksters did that were awesome and i would like to partially replicate with advice thanks
I really liked the Maelstrom build by WillyD
here some links
http://www.hometheatershack.com/for...5-shiva-x-sealed-build-3-cu-ft-completed.html
http://www.hometheatershack.com/forums/diy-subwoofers-sealed-ported/21098-new-diy-sub-3.html
http://www.hometheatershack.com/forums/exodus-audio/12134-my-sealed-maelstrom-x-build.html
Fi q sub facts
Q18
DUAL 1 | DUAL 2
Fs: 24.5 Hz | 23.8 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.66 | 5.73
Qes: .64 | .63
Qts: .58 | .57
Mms: 322g | 342g
Cms: 0.13mm/N | 0.13mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 268 l | 268 l
Spl: 89.7dB 1W/1m | 89.4dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 4-8 cuft
Ported box: 6-10 cuft @ 28Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.000”
Displacement: 0.24cuft
Thanks for the help and time guys!!!
Cheers,
KrazyBassKevin
here some links
Fi q sub facts
Q18
DUAL 1 | DUAL 2
Qms: 5.66 | 5.73
Qes: .64 | .63
Qts: .58 | .57
Mms: 322g | 342g
Vas: 268 l | 268 l
Xmax: 27mm
Rms: 1000W
Sub OD: 18.500”
Cut ID: 16.750”
Cheers,
KrazyBassKevin
