1 - 1 of 1 Posts
Super Moderator
So how do you guys figure out how much power you are applying to your sub? On other forums I see people talking about how many volts they are driving the sub with.
What they’re talking about is the voltage from their receiver’s subwoofer output jack being enough to drive the outboard amp. This is typically only something like 1-4 volts.
The reason I ask is that I am going to be playing around with a couple of Anarchy drivers in a couple of different configurations and the amp I plan to use can deliver a lot more power than these drivers can handle.
I don't want to blow up these little beasts.
Just start out with the amp’s gains set really low. Or if the amp doesn’t have any gains, start with the receiver’s sub out set low.
1 - 1 of 1 Posts
