Anyone else have this problem and resolve it?
I am using an M-Audio Fast Track Pro as my external sound card with midi connections. The REW software sees it just fine and I have selected the device in the communication tab as my midi out and FBD 1124p is set as my equalizer. I do have a cheap $15 midi cable but didn't think this mattered. The midi-out (labeled) on the cable is plugged into my M-Audio and the midi-in is plugged into the IN port on the FBD 1124p.
I turned program #5 to PA and then selected the 'send filter settings to equalizer'. The progression bar comes up just fine and completes. When I check the settings on the FBD, nothing has changed. The Store button doesn't even blink for me to accept changes.
Any ideas anyone?
I guess if push come to shove I can just enter them manually since I have just 4 filters. But downloading them is a lot nicer.
Any ideas anyone?
