R
rkruz
·Guest
I have happily gotten everything to work well when characterizing my subwoofer.
But when I down the filters (3 of them) to the BFD, it appears they are not loading. The entire bank of 12 filter LEDs is dark and 1, 2 and 3 should be lit to indicate a Parametric filter is installed.
When I upload via midi, the "in/out" button/map on the BFD flashed for a few seconds making me believe the data is being sent from the PC to the BFD. However the "Store" button does continue to flash after this is done. I manually on the BFD stored to preset 1 (2 pushes of button) but the 3 filters LEDs are not lit.
I have following the procedure to setup Midi for the BFD several times and set the Store feature to active, yet I cannot appear to upload the filter settings?
Is this a common issue? I searched the thread and poured over the help but could not find anything to help.
Anythoughts on what my problem is?
Thanks!
Thanks!
