1 - 4 of 4 Posts
Here is yet another firmware update for the 2d gen Toshiba HD DVD players. Reports are that it fixes the "Auto" setting for HDMI audio output. Others who were having a slight jitter only when using 1080p now see it gone.
http://www.tacp.toshiba.com/tacpassets-images/notices/hddvd2firmware.asp
Toshiba said:
Firmware Update Information for Owners of Toshiba HD DVD Players: Models HD-XA2, HD-A20, HD-A2, HD-A2W, and HD-D2
Firmware Update Version: 1.6
Applicable Models: HD-XA2, HD-A20, HD-A2, HD-A2W, and HD-D2.
Overview:
As part of our commitment to provide world-class service to our customers, Toshiba is supplying this firmware update for use by purchasers of Toshiba HD DVD Player models HD-XA2, HD-A20, HD-A2, HD-A2W, and HD-D2. This firmware update addresses certain disc playback and HDMI/DVI related problems identified by Toshiba.
How to obtain and install the firmware update:
If you have broadband internet service, you may obtain the firmware update over the internet using the Ethernet port on the back of your HD DVD Player. Instructions for configuring the Ethernet port and downloading the firmware update can be found in the owner’s manual for your HD DVD Player. Here is an overview of the process:
BEFORE BEGINNING THE FIRMWARE UPDATE PROCESS, BE SURE TO REMOVE ANY DISCS FROM YOUR HD DVD PLAYER.
Please configure the Ethernet port. You may need to turn on DHCP and DNS.
After you have configured the Ethernet port, follow the directions in the owner’s manual to check for a firmware update.
If a firmware update is available for your player, it will take about 20 minutes to download and install. Once the firmware update download process has finished, the player’s power will automatically switch off. You must wait until this process has finished.
DO NOT UNPLUG, TURN OFF, OR USE ANY OTHER FEATURE OF YOUR PLAYER DURING THE FIRMWARE UPDATE PROCESS. Doing so will cause the writing of the firmware update to the player to be halted and the player may no longer operate properly. If the player stops working, please contact Toshiba Customer Solutions at (800) 319-6684.
If no firmware update is available, the player will quickly exit the update process.
Please refer to the owner's manual for additional details.
If you do not have an Ethernet-based broadband connection for your player or prefer not to use one, you may contact Toshiba Customer Solutions and request that a firmware update disc be sent by mail.
You can update the firmware using this update disc by following the instructions provided with the disc.
Please note that if you sent Toshiba the Firmware Update Request card included with your player, you will receive an update disc by mail from Toshiba as soon as it becomes available.
Frequently Asked Questions:
Q1. What does this update do?
A1. This update addresses some problems Toshiba has identified with HDMI/DVI connectivity and disc playback.
Q2. When I connect my HD DVD Player to my HDTV or HD Monitor using a HDMI to DVI adaptor cable or a HDMI to DVI adaptor, the output resolution of the player remains fixed at 480i. Does the new firmware address this issue?
A2. This firmware update addresses the issue. Should you continue to experience problems, please contact Toshiba Customer Solutions at (800) 319-6684.
Q3. The HDMI output does not work or works intermittently with the HDMI or DVI input on my HDTV or monitor. Does the new firmware address that problem?
A3. The firmware update addresses and improves HDMI and DVI connectivity. If you still experience problems, try disconnecting and reconnecting the HDMI cable. Make sure your display input is set to HDMI (or DVI). If your display has more than one HDMI/DVI input, make sure that all connected HDMI/DVI source devices are powered on (even if not in use). If none of these solve the problem, please turn off the TV and the HD DVD player. Check all connections. Disconnect and reconnect the HDMI cable. Turn on the TV first and then turn on the HD DVD player. Should you continue to experience problems, please contact Toshiba Customer Solutions at (800) 319-6684.
Q4. During HD DVD playback I sometimes experience pixelization, block noise or audio dropouts. Sometimes playback freezes or stops. Sometimes, playback is not smooth. Does the new firmware address these issues?
A4. This firmware update addresses various playability issues. You should also check to be sure that the disc is clean and, if the disc will not operate at all, that you are inserting the disc with the right side up. Should you continue to experience problems, please contact Toshiba Customer Solutions at (800) 319-6684.
Q5. Do I need to install prior firmware updates before installing the current firmware update?
A5. No. The current firmware update includes all of the prior firmware updates.
Discussion Starter · #2 · (Edited)
Ok, using a HD-XA2 as a target the internet update took 28 minutes to complete to power down this early evening in the midwest. Last step 5/5 took 7 minutes. The resulting version shown is "1.6/T22T". Timed a couple of power-ups to tray open as 47 seconds. Tray close to first video display with HD DVD disc (Seabiscuit) is 30 secs.
Seabiscuit is playing very nicely right now. XA2 speakers set to "Large" (no bass management) but sub set to "on". Thunderous horse racing sounds with the SVS PC-Ultra.
Note: the XA2 did have a bass management problem with firmware 1.5 or earlier which can be avoided if you didn't ask it to do it. It seems that this new 1.6 firmware update changes this in that speakers set to "Small" now have their bass redirected to the sub like what should be done. But when you set the L/R mains to "Small" the LFE gets reduced by another 5 dB -- therefore if you can, it is best to set the L/R mains to "Large" if they can handle bass down to 40 Hz or so (-3 dB point). I have redone my system audio calibration yet again last night and have enjoyed two of the three Matrix movies so far. Playing Matrix Revolutions right now. These movies all have floor shaking bass. :T
Firmware 1.6 did change the audio bass management in the HD-XA2. I edited my previous post with some findings.
Bringing this thread back from the total and utter DEAD!!! My A-20 has started to drop audio, so I'm updating the firmware via disk - I'll report my findings and/or success tonight!
1 - 4 of 4 Posts
