1 - 2 of 2 Posts
I know this graph is off the standard scale but I copied it after setting up the filters as suggested by Bruce.
Any changes need to be done? I did drop the bump in the 55hz range a db but didn't remeasure. Target is with Bruce's "house curve".
All filters set up in FBQ manually (no MIDI cable) and it was really easy.
Looks like you have fairly good low end extension.
I would try and drop the 55Hz area a bit more, but you said you did, so you'd have to remeasure to get a look........
1 - 2 of 2 Posts
