1 - 10 of 10 Posts
So I got my USB Soundblaster X-fi card. Ran the cal Ok and saved it
Got my CM-140 and downloaded cal file and selected it. (C weighting unchecked. Meter set for C weighting, fast, 50-100)
Ran check levels in prefs. Adjusted AVR volume to give 75db on SPL
Ran SPL cal. All OK.
Set AVR to 2-ch (configured AVR for small fronts and 1 sub)
Went to measure. Ran check levels and it got this:
Don't understand why it says this or what I should do about it.
Ran measurement anyway. Got this:
Very confused
What is the phase line? Here it is without:
My master file is attached too.
If I want to measure just the sub, is it safe to disconnect the other speakers if the AVR thinks they are there? (Don't want to blow up my brand new receiver)
Regards
Mark
I had the same problem when I tried to run the test tone out of a USB mic interface (Lexicon Lambda). The only way I could get a proper sine sweep without a high pitched warble (that looked exactly like your graph) was to run the tone out of my built in sound card. To this day I have no idea where the warble was coming from
As far as the record volume being too low it's usually because the microphone or line input is too low. If you don't want to mess with that you can just boost your AVR volume. Running the test 'louder' than the 75dB setting won't ruin it.
Thanks
So did you do the sound card cal from the built in sound card to USB line in?
In the "control panel" under "sound" you can increase the mic/input level, mine was set to 30 i incresed it to 50 and this improved alot.
Try this and if no effect put it back to original settings.
Thanks
Sort of. I ended up sending the test signal from my built in sound card and recording the meter output through my USB interface, and then I increased the volume on my AVR and boosted the gain on the line in on the Lambda until it was enough. I was't too concerned with the SPL readings, just with getting it enough volume to register properly.
Discussion Starter #7
Thanks. Will give it a try.
REW Author
Measurement and soundcard cal look fine, but should redo the SPL cal as displayed levels look much higher than they should be. It is ok to disconnect speakers, also reduce the sweep frequency range when measuring just the sub.
Discussion Starter #9
Thanks John
Just want to check, there's nothing to do with SPL cal other than set value to match actuaul SPL reading and clicking finished is there?
Regards
Mark
1 - 10 of 10 Posts
