1 - 13 of 13 Posts
I've started a subwoofer project and would like to document it here. My original plan was to build a dual-driver EBS which will house two TC Sounds dB-500 12's. However, I decided to build a practice box before I dive into the huge LLT. This box will house either a single dB-500, or a single Sony Xplod 12 which is my current subwoofer. The Xplod is currently in a 2 cu ft box tuned to about 20 hz. This alignment, while better than a sealed enclosure, leaves much to be desired below and around 20 Hz. The practice box has a volume of about 4.2 ft after subtracting the brace, port, and driver volumes. Two three-inch ports will tune the enclosure to about 18 Hz.
Discussion Starter · #2 ·
As it turns out, it's a good thing I started with this practice enclosure, as my original plans for a 5 cu ft box turned into 4.2 cu ft. The pic of the front baffle should give a clue what went wrong. If it's not obvious at first, note how low the driver is sitting in the enclosure. There's 3/4-inch missing off the bottom! When I laid my design on paper and then cut the individual pieces, a miscalculation caused this mishap. I should have subtracted 3/4-inch off the sides for the panels to fit, but instead I subtracted 3/4-inch off the sides and the top of the enclosure. This made the entire front baffle 1/2-inch long all the way around the enclosure. The quickest (and cheapest) fix was to cut the front and rear baffles 3/4-inch shorter to make everything fit. Instead of bringing the ports closer to the enclosure walls, I moved the woofer closer to the bottom. Hopefully the ports will be able to work to their potential.
These pictures are basic examples of how we started actually putting the panels together. Pretty self-explanatory. The only tools we had were a router, straight-edge, cordless drill, Dremel with circle cutter, and circular saw.
Unfortunately I got busy with the woodwork and forgot to take pictures until a bit later. Here is a pic of one of the inner braces that will help brace the box as well as the ports.
Right now the silicon sealant is drying around all of the edges and I won't be able to get back to it until Saturday. I'll be able to attach the woofer, add some wiring posts, and put on the top.
One question, though... If I were to hear rattles or change the length of my ports in the future, I would need access to the inside of the box. What do I need to do to attach the "lid" without gluing it in place? I don't want it to leak at all; I will silicon around the outside edges but will that be enough? I suppose if worst comes to worse I can lay the box on its' top (with the ports close to the floor) to help attenuate any rattles. We'll see. :D
Does your SPL graphing include input power to Xmax and applied high pass filters for over excursion protection? The bracing needs to have a lot of material removed, the box won't work as shown, it has 3 separate chambers.
The picture doesn't show very well, but the braces don't completely separate the three chambers. They're each 11" long while dimensions themselves are closer to 21 x 24 x 28.
Does the air need "line of sight" to the rear or can it easily snake its' way through without causing any audible distress?
Edit: Yes, filters are applied and everything is modeled at Xmax.
Got it up and running. The room's a bit messy because I'm in the process of rearranging to make room for the sub(s) (will probably end up having two of 'em).
There's definitely a difference in output when compared to the Xplod/2ft^3 box. I only wish I would've tuned it just a hair lower, closer to 17 Hz. The output is pretty amazing right around 20 Hz (and much better between 16 & 20 than the Xplod) but I won't hardly ever be using the full potential SPL of the enclosure. Dual 3" ports 22.5 inches long tuned to about 19 Hz.
1 - 13 of 13 Posts
