Folks,
I wanna thank you all for your encouragement and ideas. As promised, here are the pics of the finished product.
The drivers are ScanSpeak 18w-8545K-00 (7") and the Focal TC120-D5
The crossover was built by Josh at Madisound... I wish I had taken a photo of it... It was also a work of art.
The Box is 1.4 CuFt. The walls are 1.5 Inches of MDF (not including the Mahogany top and bottom which were an Inch thick each...
Ports were 1.5" each by 5.2" each... Entire box was lined with Tar/Sound Deadener and then I glued Spike foam on every inch of the box inside.
First impression was GREAT! However, I have not done any measurements... I will learn to do that next.
Thanks
Dan
Thanks
Dan
