I have a customer with a CNC machine, that wants to pop out some cut parts for a Tempest-X2 slot port design. I've drawn this up to make it as simple as possible for someone to put together a killer sub, on a fairly tight budget.
Design constraints were that it needed to fit on a single sheet of 4'x8' MDF, and it had to use an off-the-shelf amplifier that had a subsonic filter that didn't need modification. In other words, you don't need to solder on the circuit board to achieve the proper filter. Easy....
I'm also working up a drawing, with a few easy modifications that will allow someone to cut their own if they have a table saw, and a router. A sheet of MDF cost about $20, the 500W version of the amplifier about $250, and the driver about $219 so the complete cost of this beast, should stay around $500 unless you want to get crazy on the finish.
I'm very confident, that there is nothing that will come remotely close to challenging it that can be bought off-the-shelf, so it represents a great bargain for anyone willing to perform a little sweat equity.
Here is the simulation, using 80% polyfill, just over 5 cubic feet and the slot port is 1.5" x 19" giving plenty of port area. Tuning frequency is around 21Hz which works great with the provided subsonic filter in the standard amp. In-room response will be into the teens and you get very good output from the ever so important 20-60hz range.
Click on this link and you can download the PDF drawing of the part. If you click on the drawing of the subwoofer in the PDF, you should be able to rotate it around and check out the design from any angle. I've made the braces blue, and the side translucent in order to easily see the inside features and port profile.
http://www.diycable.com/main/pdf/Slot-Tempest.pdf
Kevin Haskins
Exodus Audio
Kevin Haskins
Exodus Audio
