1 - 2 of 2 Posts
It fully depends on how much you use the projector and if you allow for adequate airflow around the projector. Generally a bulb will last 3000hrs but if you use it three or four days a week for several hrs a day that time can be used up quickly.
As far as price on bulbs you must be very careful as there are many aftermarket cheep bulbs available that will not last and can damage the projector or add color to the image giving undesirable tint and sutch. Make sure that it is manufactured by the OEM Epson supplier, look at the original bulb and make sure is an exact match.
There are several reputable places to get bulbs, Visual apex (their add is at the top of this page) is one of them.
1 - 2 of 2 Posts
