1 - 2 of 2 Posts
I am going to do a concrete suspended floor in the HT (and build the rest on top as a box in box) for the best possible sound damping. But I have been reading posts here and there with mentioning of a floating wooden floor, to enhance tactil sub bass feeling...
How do I do this? Is it simply a matter of putting a 3 mm foam on the concrete floor and put a wooden underfloor plus hard wood floor on top? Then this will resonate in sympathy with those deep bass tones (13 Hz) the two LLT are producing?
If you do the foam directly then go on top of it, eventually it will compress. The best way is to just build a 2x2 floor system, insulate that small cavity, then do your floor on top. That will keep the feel basically forever.
Bryan
1 - 2 of 2 Posts
