1 - 4 of 4 Posts
Hi Everyone,
Im new here and could really use your help. I am using the new version of REW 5.19 beta 8 and I am a mac user. I just purchased a Focusrite 2i2 USB and I want to make sure I am doing the REW sound card loopback calibration correctly. I was expecting flat response out to 20k the low is -3 db down at 3.7 Hz(which is correct) but I am getting -3 db down at 17.888 kHz. I know that this won't make much of a difference in real world system testing but why it it not flat as per Focusrite frequency response spec 20-20,000 +- 0.1db? The OS I am using on my MacPro laptop is 10.7.5. I did notice that the Focusrite 2i2 2nd GEN min system requirement is 10.10. I did not realize this when I ordered the unit. Its working just fine with 10.7.5 but may this hi freq rolloff possible related to this? Thanks for your help everyone.
mike
Make sure that the sample rates in REW ( preferences window ) match the sample rate chosen within the 2i2 driver's preference's window .
Which mic are you using? Is it calibrated? You will get a high frequency roll off when using a uncalibrated mic, if fact the measurements can be all over the high end.
It was an issue with the REW software and Focusrite 2i2 sample rates not matching Once that issue was solved I have crazy flat frequency responce.. that only my dog can hear. Now we are good to go. Thanks for the help!
mk
1 - 4 of 4 Posts
