1 - 20 of 35 Posts
Hi please can someone tell me which is the better choice?
Thanks in advance
I do not know much about the Scarlet. I have a Quad-Capture, though.
One thing I really like about it is the mixer panel in the device driver has a numeric gain indication for each of the two mic preamps, in 0.5 dB increments. So the gain can be set with high repeatability. It is very convenient for gain calibration.
My one complaint is that it does not have a LED indicator for Phantom Power On. Seems like a no-brainer, almost every cheap interface has one. It is not a show-stopper, though. I really like the numeric gain readout.
Hi Wayne thanks
So it has a digital control?
Thank you
Not really a digital control. The only control is the knob on the front panel of the Quad-Capture, which is an analog control, no detents, pure analog.
But there is a digital READOUT of the gain set by that knob. So it can easily be set to any desired gain, in 0.5 dB increments.
For instance, when I want to calibrate the gain for use with my BeyerDynamic MM-1 mic with REW, I know that the +27.0 dB gain setting is just right for a 75 dB SPL with a -30 dBFS measured input level. I just
  • turn on some periodic pink noise, the precise level does not matter
  • turn the input gain for the mic preamp to 27.0 dB
  • NOW adjust the REW output level so the measured input llevel is -30 dBFS on the REW SPL meter
  • click on CALIBRATE, enter 75.0 for the SPL reading, click on FINISH.
  • calibration is DONE!
Hi Wayne thank you
How do you know the 75db spl, or is there any other way of doing this?
I am trying to work out if I get the either of these two or get a plug in play mic/pre e.g. the XTZ. Please feel free to comment.
With the digital readout it would come in handy to make sure it stays at that level, instead of having mic gain pots?
Is this the UA - 55 http://www.roland.co.nz/products/quad-capture/ the one you have?
Is there another Roland UA - 55 Quad Capture or is this the only one, I thought I saw the same name but with "Professional" at the end?
Thank you, trying to understand this.
When I say "I know that the +27.0 dB gain setting is just right for a 75 dB SPL with a -30 dBFS measured input level," the only way to know this is to go through a regular level calibration using an SPL meter. This was done once a number of years ago, and is reconfirmed from time to time.
The little procedure I outlined is simply a shortcut for day-to-day REW setup, an example of what is possible with the digital gain readout. If you trust that you can simply set the knob and never move it, then the gain readout does not help you. But then what if you bump it or move it without thinking? Then you have to re-calibrate. Can you set the interface aside for a few weeks and trust the seting of that gain next time you pick it up? I am not comfortable doint that. Can you mark the position of the knob? Probably only accurate to +/- 2 or 3 dB. The readout is accurate to +/- 0.5 dB.
It is not really THAT big a deal, just a little convenience / time shortcut thing that I like.
The XTZ mic is good, it is calibrated for 90 degree use. There is no calibration file. It is made to be +/- 1 dB accurate. So there is no way to accurately use it in the 0 degree orientation, unless you create your own calibration file, which is possible but is a pain.
A USB mic or the XTZ mic will not allow you to use timing loopback for accurate time measurements. Having that feature is a must for me. I still use a UMIK-1 from time to time and have and use the XTZ mic, too, where FR is all that is needed, and no time info is necessary.
I have no experience with the Scarlet, and no idea what special features it might have.
The Quad-Capture DOES HAVE MIC GAIN POTS, like almost all audio interfaces. The digital readout tells you what the gain is set at using that pot. Turn the knob, see the readout number change accordingly, set the gain accurately where you want it with the front-panel gain pot by watching the digital gain readout.
Yes. Pretty sure I paid about $250 for mine.
It is the only one I have ever seen.
I use the 2i2 audio interface. It is a very good inexpensive audio interface for REW use. It has a couple very minor shortcomings, but is basically as capable as any of the other low priced units. Its shortcomings are unlikely to be significant for any of the typical REW applications.
I also have an easy method to calibrate the REW SPL meter when using the 2i2. It does not require an SLM. The method could be used for other similar audio interfaces as well. The advantage of the process is that it is quick and easy. It is almost as easy as the method Wayne found for the Quad-Capture Interface. It only requires a TRS to XLR loopback cable. For those that change the input gain on the audio interface between REW sessions this is much easier than using the SLM method or the method using a multi-meter. [It is basically a simplification of the multi-meter method I previously used.]
I can provide details if you or others will find this helpful.
Hi Wayne thank you very much
Does the Quad Capture have digital readouts for inputs and outputs?
I think the digital readout, this would be handy like you say for re assurance that it is exactly at the correct setting like you say bumping etc.
So I need a reference reading/point for SPL
I thought there is a XTZ pro mic calibration file?
Thanks again
I, for one, am curious what you have come up with. Please share.
Only for the first two inputs. Not for inputs 3 and 4 (digital) and not for the outputs.
Yes, initially. This can be done with a borrowed SPL meter, or with a UMIK-1 or similar calibrated USB mic that has the reference gain in the mic calibration file. Once it has been determined, and the input gain is set as described above, that reference meter or mic is no longer needed for that purpose. So, if there is a way to borrow such a reference, you will only need it for a short time. Some would want to keep a SPL measurement reference around for quick level checks or whatever, and some would be fine without it. That is your call.
Oops. Yes, you are correct, there is one. I had forgotten that.
The only driver needed is the Windows generic driver. And there is a single calibration file which works for all XTZ Pro mics, not a unique calibration file for each mic manufactured, like most other calibrated mics. The XTZ Pro mics are designed and manufactured (or selected) to work with that calibration file. The calibration file covers the range from 10 Hz to 22 kHz.
Hi thanks for your reply
I would also like to know how you did it + would this work for other programs?
Thanks again
Discussion Starter · #11 · (Edited)
+1
Ok, mainly looking at the volume output if that gets bumped?
How would I go about this?
So if the calibration covers that range does mean it is calibrated to 10hz to 22khz. I think they say 20hz-20khz?
Thanks again
Discussion Starter · #14 ·
Their set site says that measurements cover 16 Hz to 20 kHz.
It also says +/- 1 dB accuracy for the microphone.
Hi Wayne thank you
I think the program is calibrated to 16 Hz to 20 kHz (graphs)
The mic calibration covers 10hz to 23 kHz with 0 a long way down. Does tis mean it is (the pro mic) calibrated for this, strange they only say from 20 hz - 20 kHz?
Thanks for your time
Hi Wayne thank you
I do not have the program, not sure what its capabilities are.
Here is the calibration file:
Spoiler
10.00 -0.00000
10.08 -0.00000
10.16 -0.00000
10.23 -0.00000
10.31 -0.00000
10.39 -0.00000
10.47 -0.00000
10.55 -0.00000
10.64 -0.00000
10.72 -0.00000
10.80 -0.00000
10.88 -0.00000
10.97 -0.00000
11.05 -0.00000
11.14 -0.00000
11.23 -0.00000
11.31 -0.00000
11.40 -0.00000
11.49 -0.00000
11.58 -0.00000
11.67 -0.00000
11.76 -0.00000
11.85 -0.00000
11.94 -0.00000
12.03 -0.00000
12.12 -0.00000
12.22 -0.00000
12.31 -0.00000
12.41 -0.00000
12.50 -0.00000
12.60 -0.00000
12.70 -0.00000
12.80 -0.00000
12.90 -0.00000
13.00 -0.00000
13.10 -0.00000
13.20 -0.00000
13.30 -0.00000
13.40 -0.00000
13.51 -0.00000
13.61 -0.00000
13.72 -0.00000
13.82 -0.00000
13.93 -0.00000
14.04 -0.00000
14.15 -0.00000
14.25 -0.00000
14.36 -0.00000
14.48 -0.00000
14.59 -0.00000
14.70 -0.00000
14.81 -0.00000
14.93 -0.00000
15.04 -0.00000
15.16 -0.00000
15.28 -0.00000
15.40 -0.00000
15.52 -0.00000
15.64 -0.00000
15.76 -0.00000
15.88 -0.00000
16.00 -0.00000
16.12 -0.00000
16.25 -0.00000
16.38 -0.00000
16.50 0.00000
16.63 0.00000
16.76 0.00000
16.89 0.00000
17.02 0.00000
17.15 0.00000
17.28 0.00000
17.42 0.00000
17.55 0.00000
17.69 0.00000
17.82 0.00000
17.96 0.00000
18.10 0.00000
18.24 0.00000
18.38 0.00000
18.52 0.00000
18.67 0.00000
18.81 0.00000
18.96 0.00000
19.10 0.00000
19.25 0.00000
19.40 0.00000
19.55 0.00000
19.70 0.00000
19.85 0.00000
20.01 0.00000
20.16 0.00000
20.32 0.00000
20.48 0.00000
20.63 0.00000
20.79 0.00000
20.96 0.00000
21.12 0.00000
21.28 0.00000
21.45 0.00000
21.61 0.00000
21.78 0.00000
21.95 0.00000
22.12 0.00000
22.29 0.00000
22.46 0.00000
22.63 0.00000
22.81 0.00000
22.99 0.00000
23.16 0.00000
23.34 0.00000
23.52 0.00000
23.70 0.00000
23.89 0.00000
24.07 0.00000
24.26 0.00000
24.45 0.00000
24.64 0.00000
24.83 0.00000
25.02 0.00000
25.21 0.00000
25.41 0.00000
25.60 0.00000
25.80 0.00000
26.00 0.00000
26.20 0.00000
26.41 0.00000
26.61 0.00000
26.82 0.00000
27.02 0.00000
27.23 0.00000
27.44 -0.00000
27.65 -0.00000
27.87 -0.00000
28.08 -0.00000
28.30 -0.00000
28.52 -0.00000
28.74 -0.00000
28.96 -0.00000
29.19 -0.00000
29.41 -0.00000
29.64 -0.00000
29.87 -0.00000
30.10 -0.00000
30.33 -0.00000
30.57 -0.00000
30.81 -0.00000
31.04 -0.00000
31.28 -0.00000
31.53 -0.00000
31.77 -0.00000
32.02 -0.00000
32.26 -0.00000
32.51 -0.00000
32.76 -0.00000
33.02 -0.00000
33.27 -0.00000
33.53 -0.00000
33.79 -0.00000
34.05 -0.00000
34.31 -0.00000
34.58 -0.00000
34.85 -0.00000
35.12 -0.00000
35.39 -0.00000
35.66 -0.00000
35.94 -0.00000
36.22 -0.00000
36.50 -0.00000
36.78 -0.00000
37.06 -0.00000
37.35 -0.00000
37.64 -0.00000
37.93 -0.00000
38.22 0.00000
38.52 0.00000
38.82 0.00000
39.12 0.00000
39.42 0.00000
39.73 0.00000
40.03 0.00000
40.34 0.00000
40.65 0.00000
40.97 0.00000
41.29 0.00000
41.61 0.00000
41.93 0.00000
42.25 0.00000
42.58 0.00000
42.91 0.00000
43.24 0.00000
43.57 0.00000
43.91 0.00000
44.25 0.00000
44.59 0.00000
44.94 0.00000
45.29 0.00000
45.64 0.00000
45.99 0.00000
46.35 0.00000
46.70 0.00000
47.06 0.00000
47.43 0.00000
47.80 0.00000
48.17 0.00000
48.54 0.00000
48.91 -0.00000
49.29 -0.00000
49.67 -0.00000
50.06 -0.00000
50.45 -0.00000
50.84 -0.00000
51.23 -0.00000
51.62 -0.00000
52.02 -0.00000
52.43 -0.00000
52.83 -0.00000
53.24 -0.00000
53.65 -0.00000
54.07 -0.00000
54.49 -0.00000
54.91 -0.00000
55.33 -0.00000
55.76 -0.00000
56.19 -0.00000
56.63 -0.00000
57.06 -0.00000
57.51 -0.00000
57.95 -0.00000
58.40 -0.00000
58.85 -0.00000
59.31 -0.00000
59.77 0.00000
60.23 0.00000
60.69 0.00000
61.16 0.00000
61.64 0.00000
62.11 0.00000
62.59 0.00000
63.08 0.00000
63.57 0.00000
64.06 0.00000
64.55 0.00000
65.05 0.00000
65.56 0.00000
66.06 0.00000
66.57 0.00000
67.09 0.00000
67.61 0.00000
68.13 0.00000
68.66 0.00000
69.19 0.00000
69.72 0.00000
70.26 0.00000
70.81 -0.00000
71.35 -0.00000
71.91 -0.00000
72.46 -0.00000
73.02 -0.00000
73.59 -0.00000
74.16 -0.00000
74.73 -0.00000
75.31 -0.00000
75.89 -0.00000
76.48 -0.00000
77.07 -0.00000
77.67 -0.00000
78.27 -0.00000
78.87 -0.00000
79.48 -0.00000
80.10 -0.00000
80.72 -0.00000
81.34 0.00000
81.97 0.00000
82.61 0.00000
83.24 0.00000
83.89 0.00000
84.54 0.00000
85.19 0.00000
85.85 0.00000
86.52 0.00000
87.18 0.00000
87.86 0.00000
88.54 0.00000
89.22 0.00000
89.91 0.00000
90.61 0.00000
91.31 0.00000
92.02 -0.00000
92.73 -0.00000
93.45 -0.00000
94.17 -0.00000
94.90 -0.00000
95.63 -0.00000
96.37 -0.00000
97.12 -0.00000
97.87 -0.00000
98.62 -0.00000
99.39 -0.00000
100.16 -0.00000
100.93 -0.00000
101.71 -0.00000
102.50 -0.00000
103.29 0.00000
104.09 0.00000
104.90 0.00000
105.71 0.00000
106.53 0.00000
107.35 0.00000
108.18 0.00000
109.02 0.00000
109.86 0.00000
110.71 0.00000
111.57 0.00000
112.43 0.00000
113.30 0.00000
114.18 -0.00000
115.06 -0.00000
115.95 -0.00000
116.85 -0.00000
117.75 -0.00000
118.66 -0.00000
119.58 -0.00000
120.50 -0.00000
121.44 -0.00000
122.38 -0.00000
123.32 -0.00000
124.28 0.00000
125.24 0.00000
126.21 0.00000
127.18 0.00000
128.17 0.00000
129.16 0.00000
130.16 0.00000
131.16 0.00000
132.18 0.00000
133.20 0.00000
134.23 0.00000
135.27 0.00000
136.32 -0.00000
137.37 -0.00000
138.43 -0.00000
139.51 -0.00000
140.58 -0.00000
141.67 -0.00000
142.77 -0.00000
143.87 -0.00000
144.99 -0.00000
146.11 -0.00000
147.24 0.00000
148.38 0.00000
149.52 0.00000
150.68 0.00000
151.85 0.00000
153.02 0.00000
154.20 0.00000
155.40 0.00000
156.60 0.00000
157.81 -0.00000
159.03 -0.00000
160.26 -0.00000
161.50 -0.00000
162.75 -0.00000
164.01 -0.00000
165.28 -0.00000
166.56 -0.00000
167.85 -0.00000
169.15 0.00000
170.45 0.00000
171.77 0.00000
173.10 0.00000
174.44 0.00000
175.79 0.00000
177.15 0.00000
178.52 0.00000
179.90 -0.00000
181.29 -0.00000
182.70 -0.00000
184.11 -0.00000
185.53 -0.00000
186.97 -0.00000
188.41 -0.00000
189.87 0.00000
191.34 0.00000
192.82 0.00000
194.31 0.00000
195.82 0.00000
197.33 0.00000
198.86 0.00000
200.40 -0.00000
201.95 -0.00000
203.51 -0.00000
205.08 -0.00000
206.67 -0.00000
208.27 -0.00000
209.88 -0.00000
211.50 0.00000
213.14 0.00000
214.79 0.00000
216.45 0.00000
218.12 0.00000
219.81 0.00000
221.51 0.00000
223.22 -0.00000
224.95 -0.00000
226.69 -0.00000
228.45 -0.00000
230.21 -0.00000
231.99 -0.00000
233.79 0.00000
235.60 0.00000
237.42 0.00000
239.26 0.00000
241.11 0.00000
242.97 0.00000
244.85 -0.00000
246.75 -0.00000
248.65 -0.00000
250.58 -0.00000
252.52 -0.00000
254.47 0.00000
256.44 0.00000
258.42 0.00000
260.42 0.00000
262.44 0.00000
264.47 0.00000
266.51 -0.00000
268.57 -0.00000
270.65 -0.00000
272.75 -0.00000
274.86 -0.00000
276.98 0.00000
279.12 0.00000
281.28 0.00000
283.46 0.00000
285.65 0.00000
287.86 -0.00000
290.09 -0.00000
292.33 -0.00000
294.60 -0.00000
296.87 -0.00000
299.17 0.00000
301.49 0.00000
303.82 0.00000
306.17 0.00000
308.54 -0.00000
310.92 -0.00000
313.33 -0.00000
315.75 -0.00000
318.19 -0.00000
320.66 0.00000
323.14 0.00000
325.64 0.00000
328.16 0.00000
330.69 -0.00000
333.25 -0.00000
335.83 -0.00000
338.43 -0.00000
341.05 0.00000
343.69 0.00000
346.34 0.00000
349.02 0.00000
351.72 -0.00000
354.44 -0.00000
357.19 -0.00000
359.95 -0.00000
362.73 0.00000
365.54 0.00000
368.37 0.00000
371.22 0.00000
374.09 -0.00000
376.98 -0.00000
379.90 -0.00000
382.84 -0.00000
385.80 0.00000
388.78 0.00000
391.79 0.00000
394.82 -0.00000
397.88 -0.00000
400.96 -0.00000
404.06 -0.00000
407.18 0.00000
410.33 0.00000
413.51 0.00000
416.71 -0.00000
419.93 -0.00000
423.18 -0.00000
426.45 -0.00000
429.75 0.00000
433.08 0.00000
436.43 0.00000
439.80 -0.00000
443.20 -0.00000
446.63 -0.00000
450.09 0.00000
453.57 0.00000
457.08 0.00000
460.61 -0.00000
464.18 -0.00000
467.77 -0.00000
471.39 0.00000
475.03 0.00000
478.71 0.00000
482.41 -0.00000
486.14 -0.00000
489.90 -0.00000
493.69 0.00000
497.51 0.00000
501.36 0.00000
505.24 -0.00000
509.15 -0.00000
513.09 -0.00000
517.06 0.00000
521.06 0.00000
525.09 -0.00000
529.15 -0.00000
533.24 -0.00000
537.37 0.00000
541.53 0.00000
545.72 0.00000
549.94 -0.00000
554.19 -0.00000
558.48 0.00000
562.80 0.00000
567.15 0.00000
571.54 -0.00000
575.96 -0.00000
580.42 0.00000
584.91 0.00000
589.43 -0.00000
593.99 -0.00000
598.59 -0.00000
603.22 0.00000
607.88 0.00000
612.59 -0.00000
617.33 -0.00000
622.10 -0.00000
626.91 0.00000
631.76 0.00000
636.65 -0.00000
641.58 -0.00000
646.54 0.00000
651.54 0.00000
656.58 -0.00000
661.66 -0.00000
666.78 0.00000
671.94 0.00000
677.13 -0.00000
682.37 -0.00000
687.65 0.00000
692.97 0.00000
698.33 -0.00000
703.73 -0.00000
709.18 0.00000
714.66 0.00000
720.19 -0.00000
725.76 -0.00000
731.38 0.00000
737.04 0.00000
742.74 -0.00000
748.48 -0.00000
754.28 0.00000
760.11 0.00000
765.99 -0.00000
771.92 -0.00000
777.89 0.00000
783.91 -0.00000
789.97 -0.00000
796.08 0.00000
802.24 0.00000
808.45 -0.00000
814.70 -0.00000
821.00 0.00000
827.35 0.00000
833.75 -0.00000
840.20 0.00000
846.70 0.00000
853.25 -0.00000
859.85 0.00000
866.51 0.00000
873.21 -0.00000
879.96 -0.00000
886.77 0.00000
893.63 -0.00000
900.54 -0.00000
907.51 0.00000
914.53 -0.00000
921.61 -0.00000
928.74 0.00000
935.92 -0.00000
943.16 -0.00000
950.46 0.00000
957.81 -0.00000
965.22 -0.00000
972.69 0.00000
980.21 -0.00000
987.79 -0.00000
995.44 0.00000
1003.14 -0.00000
1010.90 0.00000
1018.72 0.00000
1026.60 -0.00000
1034.54 0.00000
1042.54 0.00000
1050.61 -0.00000
1058.73 0.00000
1066.92 -0.00000
1075.18 -0.00000
1083.50 0.00000
1091.88 -0.00000
1100.32 0.00000
1108.84 -0.00000
1117.41 -0.00000
1126.06 0.00000
1134.77 -0.00000
1143.55 0.00000
1152.39 -0.00000
1161.31 -0.00000
1170.29 0.00000
1179.35 -0.00000
1188.47 0.00000
1197.66 -0.00000
1206.93 0.00000
1216.27 -0.00000
1225.68 -0.00000
1235.16 0.00000
1244.71 -0.00000
1254.34 0.00000
1264.04 -0.00000
1273.82 0.00000
1283.68 -0.00000
1293.61 0.00000
1303.62 -0.00000
1313.70 0.00000
1323.86 0.00000
1334.10 -0.00000
1344.42 0.00000
1354.82 -0.00000
1365.31 0.00000
1375.87 -0.00000
1386.51 0.00000
1397.24 -0.00000
1408.05 0.00000
1418.94 -0.00000
1429.92 0.00000
1440.98 -0.00000
1452.12 0.00000
1463.36 -0.00000
1474.68 0.00000
1486.09 0.00000
1497.58 -0.00000
1509.17 0.00000
1520.84 -0.00000
1532.61 0.00000
1544.46 -0.00000
1556.41 0.00000
1568.45 -0.00000
1580.59 0.00000
1592.81 -0.00000
1605.14 -0.00000
1617.55 0.00000
1630.07 -0.00000
1642.68 0.00000
1655.38 -0.00000
1668.19 0.00000
1681.10 0.00000
1694.10 -0.00000
1707.21 0.00000
1720.41 -0.00000
1733.72 0.00000
1747.13 0.00000
1760.65 -0.00000
1774.27 0.00000
1788.00 0.00000
1801.83 -0.00000
1815.77 0.00000
1829.81 -0.00000
1843.97 -0.00000
1858.23 0.00000
1872.61 -0.00000
1887.09 -0.00000
1901.69 0.00000
1916.40 -0.00000
1931.23 -0.00000
1946.17 0.00000
1961.22 0.00000
1976.40 -0.00000
1991.69 0.00000
2007.09 0.00000
2022.62 -0.00000
2038.27 -0.00000
2054.04 0.00000
2069.93 0.00000
2085.94 -0.00000
2102.08 -0.00000
2118.34 0.00000
2134.72 0.00000
2151.24 -0.00000
2167.88 -0.00000
2184.65 0.00000
2201.55 0.00000
2218.58 -0.00000
2235.74 -0.00000
2253.04 -0.00000
2270.47 0.00000
2288.03 0.00000
2305.73 0.00000
2323.57 -0.00000
2341.55 -0.00000
2359.66 -0.00000
2377.91 0.00000
2396.31 0.00000
2414.85 0.00000
2433.53 -0.00000
2452.35 -0.00000
2471.33 -0.00000
2490.44 -0.00000
2509.71 -0.00000
2529.13 0.00000
2548.69 0.00000
2568.41 0.00000
2588.28 0.00000
2608.30 0.00000
2628.48 -0.00000
2648.81 -0.00000
2669.30 -0.00000
2689.95 -0.00000
2710.76 -0.00000
2731.73 -0.00000
2752.86 -0.00000
2774.16 -0.00000
2795.62 -0.00000
2817.25 -0.00000
2839.04 -0.00000
2861.00 -0.00000
2883.14 -0.00000
2905.44 -0.00000
2927.92 -0.00000
2950.57 -0.00000
2973.39 0.00000
2996.39 0.00000
3019.57 0.00000
3042.93 0.00000
3066.47 0.00000
3090.20 0.00000
3114.10 -0.00000
3138.19 -0.00000
3162.47 -0.00000
3186.93 -0.00000
3211.59 0.00000
3236.43 0.00000
3261.47 0.00000
3286.70 -0.00000
3312.13 -0.00000
3337.75 -0.00000
3363.57 0.00000
3389.59 0.00000
3415.81 -0.00000
3442.24 -0.00000
3468.86 -0.00000
3495.70 0.00000
3522.74 0.00000
3549.99 -0.00000
3577.46 -0.00000
3605.13 0.00000
3633.02 -0.00000
3661.13 -0.00000
3689.45 0.00000
3717.99 -0.00000
3746.75 -0.00000
3775.74 0.00000
3804.94 -0.00000
3834.38 -0.00000
3864.04 0.00000
3893.93 -0.00000
3924.06 0.00000
3954.41 0.00000
3985.01 0.00004
4015.83 0.00025
4046.90 0.00078
4078.21 0.00174
4109.75 0.00329
4141.55 0.00557
4173.59 0.00857
4205.87 0.01249
4238.41 0.01746
4271.20 0.02335
4304.24 0.03045
4337.54 0.03889
4371.09 0.04859
4404.91 0.05961
4438.98 0.07223
4473.32 0.08616
4507.93 0.10121
4542.80 0.11754
4577.94 0.13475
4613.36 0.15306
4649.05 0.17341
4685.01 0.19519
4721.26 0.21613
4757.78 0.23652
4794.59 0.25722
4831.68 0.27775
4869.05 0.29821
4906.72 0.32043
4944.68 0.34224
4982.93 0.36501
5021.48 0.38897
5060.32 0.41290
5099.47 0.43820
5138.92 0.46405
5178.67 0.48975
5218.74 0.51686
5259.11 0.54397
5299.79 0.57215
5340.79 0.60083
5382.11 0.62906
5423.74 0.65905
5465.70 0.68870
5507.98 0.71899
5550.59 0.75015
5593.53 0.78129
5636.80 0.81375
5680.41 0.84576
5724.35 0.87828
5768.64 0.91097
5813.26 0.94309
5858.23 0.97536
5903.55 1.00730
5949.22 1.03912
5995.25 1.07181
6041.62 1.10460
6088.36 1.13754
6135.46 1.17075
6182.92 1.20336
6230.76 1.23604
6278.96 1.26874
6327.53 1.30090
6376.48 1.33359
6425.81 1.36576
6475.52 1.39877
6525.61 1.43261
6576.09 1.46639
6626.97 1.50208
6678.23 1.53779
6729.89 1.57408
6781.96 1.61283
6834.42 1.65154
6887.29 1.69278
6940.57 1.73547
6994.26 1.77815
7048.37 1.82499
7102.90 1.87209
7157.85 1.92075
7213.22 1.97183
7269.02 2.02293
7325.25 2.07790
7381.92 2.13362
7439.03 2.18984
7496.57 2.25013
7554.57 2.31018
7613.01 2.37205
7671.90 2.43575
7731.25 2.49839
7791.06 2.56390
7851.33 2.62942
7912.07 2.69442
7973.28 2.76052
8034.96 2.82549
8097.12 2.89101
8159.76 2.95554
8222.88 3.01960
8286.49 3.08183
8350.59 3.14370
8415.19 3.20469
8480.29 3.26467
8545.90 3.32437
8612.01 3.38176
8678.63 3.43867
8745.77 3.49531
8813.42 3.55085
8881.61 3.60689
8950.31 3.66341
9019.55 3.72066
9089.33 3.77742
9159.64 3.83866
9230.50 3.89956
9301.91 3.96294
9373.87 4.03063
9446.38 4.09850
9519.46 4.17228
9593.10 4.24904
9667.31 4.32641
9742.10 4.41131
9817.46 4.49626
9893.41 4.58505
9969.95 4.67725
10047.07 4.76855
10124.80 4.86560
10203.12 4.96208
10282.05 5.06015
10361.59 5.15938
10441.75 5.25825
10522.53 5.35778
10603.93 5.45736
10685.96 5.55663
10768.63 5.65701
10851.93 5.75692
10935.88 5.85671
11020.48 5.95815
11105.74 6.05908
11191.65 6.16139
11278.23 6.26443
11365.48 6.36786
11453.40 6.47292
11542.00 6.57823
11631.29 6.68594
11721.27 6.79407
11811.94 6.90245
11903.32 7.01315
11995.41 7.12326
12088.20 7.23313
12181.71 7.34298
12275.95 7.45221
12370.92 7.55985
12466.62 7.66661
12563.06 7.77220
12660.25 7.87500
12758.19 7.97656
12856.88 8.07548
12956.34 8.17166
13056.57 8.26741
13157.58 8.35698
13259.37 8.44582
13361.94 8.53259
13465.31 8.61386
13569.47 8.69532
13674.45 8.77122
13780.23 8.84476
13886.83 8.91769
13994.26 8.98312
14102.52 9.04873
14211.62 9.10968
14321.56 9.16612
14432.35 9.22206
14544.00 9.26896
14656.51 9.31443
14769.89 9.35690
14884.15 9.39022
14999.29 9.42356
15115.33 9.44815
15232.26 9.46816
15350.10 9.48777
15468.84 9.49354
15588.51 9.49938
15709.10 9.49913
15830.63 9.49044
15953.09 9.48160
16076.50 9.46078
16200.87 9.43692
16326.20 9.40962
16452.50 9.37052
16579.78 9.33031
16708.04 9.28135
16837.29 9.22551
16967.54 9.16778
17098.80 9.09719
17231.08 9.02393
17364.38 8.94452
17498.71 8.85566
17634.08 8.76340
17770.49 8.66219
17907.96 8.55498
18046.50 8.44234
18186.11 8.32230
18326.79 8.19654
18468.57 8.06656
18611.44 7.93052
18755.42 7.78730
18900.51 7.64533
19046.72 7.49571
19194.07 7.34141
19342.55 7.18929
19492.18 7.02793
19642.97 6.86982
19794.93 6.70978
19948.06 6.53947
20102.38 6.38330
20257.89 6.21606
20414.61 6.05005
20572.53 5.88916
20731.68 5.71710
20892.06 5.55914
21053.68 5.39588
21216.55 5.22746
21380.68 5.07215
21546.08 4.90519
21712.76 4.74558
21880.73 4.58612
22050.00 4.41652
Sorry, I did not look close at it before, just glanced at the freq limits. The HF numbers look for real, the LF numbers I wonder about. Zero error at 10 Hz for all the mics they make? Doubtful.
I made backup copies and dated the file when I got it from them, so I am sure I did not modify the file, something I have done experimentally before, but NEVER without great care to then either delete it or document what the changes were, so I am confident it is the way it came from XTZ.
Don't know what to say... They advertise 1 dB accuracy down to 16 Hz, that is probably what I would assume is correct.
Discussion Starter · #17 · (Edited)
Hi Wayne thanks I wondered about the lower frequencies.
Please can you clarify for XLR mics, I have a Steinberg CI-1 pre-soundcard
• For loopback Input 2 to output 2 TRS > TRS or XLR > TRS
• For SPL calibration Input 2 to output 2 TRS > TRS
• For mic cable should be XLR > XLR
For the loopback should the input level (2 or B can't remember) be the same as the mic input or does it not matter?
With SPL using DVM do I measure the input 2 or the mic (input 1)?
Maybe quicker if you could post a photo of the setup (if you can of course)?
Thanks again
timing loopoback: TRS - TRS
SPL calibration: TRS - TRS
mic: XLR - XLR
It does not matter.
not sure, I'll get back to you
1 - 20 of 35 Posts
