1 - 12 of 12 Posts
Is there a better sounding driver than the Fostex FE103 from 80hz to 1k? Looking to build some 3 ways. I love the FE but was wondering if there was something better out there that would work in a Transmission Line? :rolleyes:
Matt
Discussion Starter · #2 · (Edited)
They will be doing middbass from 80hz to 1000k then a first order crossover will be used to hand off the duties to a NEO8 and then from there to a NEO3 to finish out the highs. So I am looking for a midbass that behaves nice without to many time delay or phase issues. I will be using a quarter wave transmission line to house the middbass. Maybe the Fostex FE127E?
Matt
As with everything in the insane hobby of ours, personal taste is king, but I think that website is great for the unbiased (as much as you can be) notes and test results.
Good luck and please keep us informed on your decision process.
· Super Moderator
That is a subjective question and thus impossible to answer definitively.
I would opine yes, since the volume displacement capability of that driver means extremely limited SPL @ 80hz, with high levels of IMD. That appears to be a 4" midrange driver. I would not use it below 300-400hz and even then, only with low SPL requirements.
Matt
A TL for the midrange? :scratch:
cheers,
AJ
ya, my thoughts precisely, although a lot of people are building TL's out of the Fostex full range drivers. I just does not seem like nearly enough displacement. The Xmax is tiny. Any recommendations on a driver to use to cover the freq between 80hz and 1000hz? Would like it to have a low Qts to make it suitable for use in a TL.
Matt
WOW ajinfla you are a mind reader. ! I just hooked up my first pair of Mark Audio CHR-70's and WOW!!!!!!!!! They are running free air, and they sound awesome! I can not wait to get them integrated with some planar mids and highs. Thanks again!!!!!!
Matt
Well I built a TL for the CHR 70's and they are INCREDIBLE!!! I was able to get a -3db point of 38hz using a transmission line enclosure!! It was amazing to listen to a 4 inch driver do 35hz!!!!!!!!!!!!! Of course I was using two per enclosure to get any kind of volume and will end up using 4 drivers per enclosure. I am going to order the alpair 6's next and give them a test run. THIS IS FUN. :bigsmile:
Matt
1 - 12 of 12 Posts
