21 - 40 of 77 Posts
CalMAN 5.4.0 RC2 - Build: 1816 Released @ 05 December 2014
Changes (since RC1)
Added support for APL Patterns with madTPG. Requires madVR 0.87.11 or greater
When connecting to madTPG, CalMAN will attempt to connect over the local interface first. If this fails, it will then fall back to the entered IP Address.
Resolved issue with APL Patterns with ASSIMILATE SCRATCH.
Resolved issue with 3D LUT calibration on the 5 point Radiance models.
Enhancements to 3D LUT profile interpolation for better results near black.
Download Links
CalMAN 5.4.0 Final - Build: 1829 Released @ 18 December 2014
New Features
Lightning LUT Technology: generate corrective 3D LUTs in five minutes or less. CalMAN’s new Lightning LUT technology allows users to quickly correct the output of their video monitors. Unique interpolation algorithms allow CalMAN to provide an accurate 3D LUT calibration while only reading a select number of points in a 3D colorspace. Available in CalMAN Ultimate.
IR Profiling (Intelligent Resolution Profiling): create corrective 3D LUTs that fit your unique needs and time constraints. The process of creating a 3D LUT in CalMAN now offers users the option of setting specific time and quality preferences before beginning a 3D LUT calibration. Create a 3D LUT in under an hour or set no time constraints for a maximum quality calibration. Available in CalMAN Ultimate and CalMAN Professional.
LUT Retargeting: create multiple 3D LUTs for your monitor, each with different colorspace standards, with only one set of readings. CalMAN is now able to convert any LUT file to a new colorspace. Have you created a corrective 3D LUT for Rec.709 but also need one for D-Cinema? Use the display tab in CalMAN to create a D-Cinema 3D LUT from any other CalMAN LUT file. Available in CalMAN Ultimate. Note: it is recommended that users start with a larger colorspace 3D LUT and retarget to a LUT with a smaller colorspace.
Free CalMAN Eyeglass 3D LUT Visualization Tool: upload your own photos to SpectraCal's free 3D LUT visualization tool to compare before-and-after results of 3D LUT calibrations. Located in the CalMAN Main Menu.
Added support for ASSIMILATE SCRATCH® and SCRATCH Lab® digital workflows as pattern generators. Supported in CalMAN Ultimate.
Added ASSIMILATE SCRATCH to the format drop-down on the SpectraCal Cube Generator.
Added support for the Lumagen Radiance 21xx series video processors with higher baud rate when using the built-in USB connection in CalMAN Professional and CalMAN Ultimate.
Added support for the Colorimetry Research CR-100 colorimeter and CR-250 spectroradiometer in all license levels of CalMAN for Business.
Added support for Photo Research AQL meter.
Updated keyboard shortcuts for greater usability. New shortcuts are as follows:
A = AutoCal/AutoCube
C = Continuous Read
H = Read Grayscale High
L = Read Grayscale Low
S = Series Read
X = Stop
Arrow Key Right = Next Workflow Page
Arrow Key Left = Previous Workflow Page
Space Bar = Single Read
Added new Lightning LUT workflow to CalMAN Ultimate. Provides 3D LUT calibrations exclusively with CalMAN’s new Lightning LUT technology.
Changes
Updated interface for the new HP DreamColor firmware (v.230)
BT.1886 is now available in the CalMAN DDC controls for the Panasonic AX900 series displays.
Made enhancements to 3D LUT profile interpolation for better results near black (CalMAN Ultimate).
Optimized memory usage loading and unloading workflows.
Resolved Issues
Resolved issue where target lines weren't drawing on deltaE charts in reports.
Resolved issue where White and Black points were incorrect on Saturations Sweeps when in PC Levels.
Resolved issue with the VP401 where patterns could get out of sync.
Resolved issue with APL patterns in ASSIMILATE SCRATCH (CalMAN Ultimate).
Resolved issue with 3D LUT calibration on the 5-point Radiance models.
Resolved performance issues with deltaE charts.
Notes
For Workflow Designers using CalMAN’s Design Mode Feature: We have uncoupled the in workflow pattern window for performance reasons. This means that CalMAN will not wait for this window to update before taking a reading. In cases where you have created workflows which use these windows for taking readings, you will need to make a modification. When getting properties on these windows, you will see a new option called Sync Pattern for Calibration. You will want to check this box if the window is used for taking active readings. All workflows created before this change will have that box unchecked.
We recommend you remove the zoomed in CIE chart you might have on 3D Cube calibration layouts. This window can cause CalMAN to crash during calibration.
Download Links
CalMAN ColorChecker Now Includes 3D LUT Visualization Features
See how accurate your monitor could be with new virtual 3D LUT capabilities and a free LUT visualization tool.
Now you can do more than test the accuracy of your display. Create a virtual 3D LUT in ColorChecker to see the difference a calibration could make! CalMAN can now create a virtual correction matrix unique to your monitor's color performance so you can see just how good your display could be. Once you've created the virtual 3D LUT in ColorChecker, upload your own photos and images to CalMAN Eyeglass and see the before-and-after effects of your corrective 3D LUT.
Download CalMAN 5.4 ColorChecker (Free Version) to get started.
(Above: photo viewed in CalMAN Eyeglass with corrective 3D LUT uploaded. Photo is rendered in split screen with the native display output on the left, and the corrected output on the right. This image is for demonstrative purposes only and will appear differently on different displays.)
Download CalMAN ColorChecker QuickStart Guide
CalMAN 5.4.0a - Build: 1831 Released @ 24 December 2014
Download Links
CalMAN 5.4.0b - Build: 1833 Released @ 29 December 2014
New Features
This adds the HP DreamColor II and Eizo (1D) displays as well as pattern generators to the Studio Lite license.
Resolved Issues
Fixes a crash when closing the Meter Profiling window.
Download Links
See CalMAN Eyeglass in action! Load you own photos and images into CalMAN Eyeglass to see the before-and-after effects of your 3D LUT calibrations. Watch this video to learn more about SpectraCal’s new 3D LUT visualization tool with complete instructions on how to use it yourself. CalMAN Eyeglass in included free with the download of CalMAN ColorChecker (Free Version).
CalMAN 5.4.1 Open Beta - Build: 1847 Released @ 14 January 2015
New Features
Added Include Black in AutoCal Adjustments check box. This is available under the Workflow Advanced Options tab. This is saved with the workflow. Prior to this change, if you selected a specific Black Level, CalMAN would attempt to calibrate black to this specified level.
With this box unchecked, CalMAN will instead use this as the value of black for its calibration calculations. Black will not be adjusted, but the targets will be calculated using this specified black.
New History runtype. For you workflow developers, there is a new run type called History. This cal allow you to take multiple readings repeated readings and have them all chart together. In order for this to work, you need to set the layout to History and your graphs to History. There need to be at least one chart on the layout which is set to the runtype of your readings.
For example: if I wanted to have a history of how 100% reads over time, I might throw out an RGB chart and a luminance chart set to history. I might then also add a RGB chart set to single point which is set to grayscale. For grayscale points on the layout, I would set it to White Only.
We'll work on putting together a demo layout/workflow to show this new feature off. In the mean time, we'd love to get feedback from you out there on how you view this new feature and see what tasks you can come up for it. :)
Changes & Fixes
Resolved licensing issue for the CR-250 meter
CalMAN now requires version 0.87.13 of madVR. No new functionality yet, but some is coming that requires a later version.
Download Links
CalMAN 5.4.1 Open Beta - Build: 1852 Released @ 22 January 2015
Release Notes
Added a Points remaining count for all point based AutoCubes.
Added a Dataset Segment Size. This allows the user to segment a very large dataset into smaller pieces for display in a layout. When the number of datapoints exceeds the set amount, a selection box appears on the left side of the slider bar, allowing the user to switch between segments. By default this is set to 500 points. This can be done under Settings\Advanced Measurement Options and is only available for ColorChecker or History run types.
Interactive AutoCube (legacy) has been re enabled for those users who wish to use it. This can be enabled under Settings\Application Measurement Options.
Resolved an issue where the .3dx (Eyeglass) LUT file was not being written after an AutoCube if Include Black in AutoCal Adjustments was unchecked.
Resolved a licensing issue which would cause CalMAN to crash if the user entered a Studio Lite license with an existing Studio Express license.
Download Links
CalMAN 5.4.1 Open Beta - Build: 1856 Released @ 30 January 2015
Release Notes
Added support for the following 2014 EIZO models
CG247, CG277, CX241, an CX271
Download Links
CalMAN 5.4.1 RC1 - Build: 1862 Released @ 05 February 2015
New Features
Added "Include Black" option in AutoCal Adjustments checkbox. This is available under the Workflow Advanced Options tab and is saved with the workflow. With this box unchecked, CalMAN will not adjust absolute black in calibrations, but custom black level targets may still be set within the workflow.
Added "Points Remaining" indicator to progress windows for point-based 3D LUT calibrations.
Added support for 2014 EIZO models: CG247, CG277, CX241 and CX271.
Added support for new firmware for Colorimetry Research meters (CR-100, CR-250) that improves meter syncing.
Ultimate License Only: added new History runtype that allows users to display multiple readings on the same chart.
Ultimate License Only: added ST.2084 gamma formula for high dynamic range (HDR) displays.
Enthusiast License Only: added new History runtype that allows users to display multiple readings on the same chart.
Changes
Changed default setting for input and output on the DVDO TPG to "Limited." This assures the output levels of the device are not compressed.
CalMAN support for madVR pattern generator and 3D LUTs now requires version 0.87.13 of the madVR software.
Computer monitor workflows no default to full PC levels (0-255) for compatibility with the sRGB gamma standard.
Resolved Issues
Resolved licensing issue with the CR-250 spectroradiometer.
Resolve an issue that would cause CalMAN to crash or stop during a 3D LUT calibration or LUT retargeting.
Resolved an issue that prevented workflow charts from updating properly.
Download Links
CalMAN 5.4.1 RC2 - Build: 1868 Released @ 12 February 2015
New Features
Coming Soon...
Changes
Coming Soon...
Resolved Issues
Coming Soon...
Download Links
CalMAN 5.4.1 Open Beta - Build: 1876 Released @ 20 February 2015
Changes & Fixes
1) Hopefully we have fixed the crashes people have been seeing. These are generic Windows crashes, which cause CalMAN to just exit.
2) Hopefully have resolved an issue which could cause CalMAN to hang (or go run off to play with the faeries) at the end of a cube calibration. The dialog box is still there, the progress bar still moves, but no progress is made.
3) Changed the meter mode default for the CR-250 from Fast 2x to Normal
4) Reduced discontinuities in the WTW region of a WTW LUT when only profiling to reference white.
5) Resolved issue that would cause points to remain on any chart which used a filtered data set. This was most noticeable on the CIE chart during cube calibrations.
Download Links
I am ashamed to say, I tried the free Calman studio DL and just can't figure it out :(
Tried it for 2-3hours, watched videos and tried again. how do I get it to do more then the basic stuff and actually get to give me the option to save a profile to my pc?
The 3d Cube thing just shows me what image will looklike after adjustments, which looks worse then the before image, lots of yellow/brown instead of white in the image.
Wanted to calibrate my projectors seperately due to one having a green tint and other having a darker violet tint due to running passive 3d filter kit.
CalMAN 5.4.1 - Build: 1891 Released @ 05 March 2015
New Features
Added LCD LED Blue/Green colorimeter tables for X-Rite i1Display Pro (OEM and retail).
Changes
Computer monitor workflows now default to full PC levels (0-255) for compatibility with the sRGB gamma standard.
Changed meter mode default for the CR-250 from Fast 2x to Normal.
CalMAN now writes 3D LUT/profile files directly to the hard drive previous to writing the files to 3D LUT hardware.
CalMAN now supports up to 99 different meter tables for the Klein K10 devices.
Resolved Issues
Resolved an issue that prevented CalMAN from writing 1D LUTs to EIZO CX models.
Resolved an issue that caused CalMAN to crash when connecting to the SpectraCal C3 colorimeter.
Corrected luminance scaling issue in meter profiles.
Resolved an issue with CalMAN PC levels for the DVDO TPG.
Resolved an issue with data plotting for charts with a filtered data set. This was especially noticeable on CIE charts during 3D LUT calibrations.
Reduced discontinuities in the whiter-than-white (WTW) region of a 3D LUT when profiling to reference white (235).
Known Issues
There is a known issue with Windows 8 and the Blackmagic Design HDLink drivers which cause CalMAN to crash when writing to the device.
Download Links
CalMAN 5.4.2 - Build: 1901 Released @ 17 March 2015
Changes
Added a minor delay to the Assimilate SCRATCH and madTPG pattern generators.
Changed DDC setting in CalMAN Client 3 to be disabled by default, rather than enabled.
CalMAN Client 3 now supports Mac OS X Yosemite, version 10.10.2.
Updated Monitor-Standard and Monitor-Advanced workflows.
Resolved Issues
Resolved an issue with the CR-100 that would cause CalMAN to crash when no light was being read by the meter.
Resolved an issue where CalMAN would crash or hang when scaling during a 3D LUT calibration or retargeting.
Resolved an issue with the NIST Certification section in the Meter Connect Tab.
Download Links
CalMAN 5.4.2 - Build: 1911 Released @ 30 March 2015
Changes
Not yet announced.
Download Links
CalMAN 5.4.2b - Build: 1912 Released @ 10 April 2015
Resolved Issues
Resolved an issue where an iRP Cube calibration would ignore the specified or read black when making its calculations. This could cause gamma to be off in some situations.
Resolved an issue where CalMAN would crash when connecting to Client 3 as a Display with DDC enabled on some monitors.
Download Links
CalMAN 5.5.0 Open Beta - Build: 1922 Released @ 10 April 2015
New Features
Added support for software 1D LUTs using the SpectraCal CalMAN Cube Generator.
Added support for the Prisma 3D LUT Box.
Added additional 1D LUT points for the isMini. (61 for Video and 65 for PC).
Resolved crash in CalMAN when closing madTPG after having disconnected.
Resolved an issue where CalMAN was using 0 for black level with iRP 3D Cubes instead of the read or specified blacks. This would throw off gamma.
Resolve a crash in CalMAN when connecting to Client 3 as a display with DDC enabled for some monitors.
Added support for the new version of Virtual Forge for Mac and the new Virtual Forge for Windows.
The ports Virtual Forge uses have changed. For the new versions, you will want to connect via SpectraCal instead of AVFoundry.
Download Links
CalMAN 5.5.0 Open Beta - Build: 1935 Released @ 14 May 2015
Release Notes
Added ST 2084 to the Studio license.
Added the ability to manually specify a sync number for the CR-100 meter.
DeltaE charts no longer display target lines by default. They can be enabled by those with design mode on the properties for the chart.
Values for the target lines for DeltaE charts have changed. They are now at 1,3, and 10 instead of 3,5, and 10.
Improved or resolved issue where deltaE charts might not populate in reports.
Resolved issue that caused the Expand Video to PC Levels check box for the Mobile Forge pattern generator to not work.
Download Links
CalMAN 5.5.0 - Build: 1952 Released @ 10 June 2015
New Features
Added support for software 1D LUTs in raw .csv format (CalMAN Ultimate).
Added support for Prisma 3D LUT Box (CalMAN Ultimate/Enthusiast).
Changes
Added additional calibration points for Fujifilm IS-Mini 3D LUTs (video 61 points, PC 65 points).
New versions of VirtualForge can now be found in the Manufacturer dropdown of the CalMAN Source Tab under "SpectraCal", as opposed to "AVFoundry." VirtualForge will remain listed under AVFoundry for any versions previous to build 1.1.302.
Added ability for users to specify a manual sync number for the CR-100 meter.
DeltaE charts no longer display target lines by default. The lines, when enabled, display targets at 1, 3 and 10 as opposed to 3, 5 and 10 as they were previously.
Mouse-overs for DeltaE charts now display a ColorChecker swatch for the selected color as well as the DeltaE value.
Disabled the "Include Stabilizing Delay for Read All" setting by default.
CalMAN will no longer calculate Contrast Ratio unless both black and white readings have been taken.
Resolved Issues
Resolved crashes that occasionally occurred when connecting to Client 3 as a display.
Resolved issue with IR Profiling black level targets.
Resolved issue with "Expand to PC Levels" option in the Source Control Tab.
Resolved data population issue for DeltaE charts in reports.
Resolved looping issue with point-based IR Profiling.
Resolved issue with 4-Color-Matrix tool.
Download Links
21 - 40 of 77 Posts
