41 - 60 of 77 Posts
CalMAN 5.5.1 Preview - Build: 1964 Released @ 02 July 2015
''With the holiday weekend swiftly approaching, we decided to do a 5.5.1 preview release to the forums. This is basically 5.5.1 final, but is not going up on the web site until next week.''
Release Notes
Added support for OSEE as pattern generator for Ultimate, Studio, and ColorChecker license levels.
Added the OSEE file format for cube calibrations in SpectraCal Cube Generator.
Added a check box on the Source tab for madVR to force it into full screen mode while CalMAN takes readings. The window will be returned to its previous state when readings are done. This requires madVR version 0.88.14 or higher.
Resolved issue where Target lines on deltaE charts might not display once enabled.
Added Rec BT.2020 UHD and D65 P3 Gamuts to Studio Express and Studio Lite licenses.
Resolved an issue where Pattern Auto Advance would apply to an automated pattern generator.
Resolved an issue on the Lumagen Radiance (all models) where CalMAN would not reset the internal 3D LUT at the start of a cube calibration.
Resolved an issue where CalMAN would not recreate a settings file on startup if it were missing. This would cause CalMAN to crash on startup.
Fixed typo on the ColorChecker button on the last layout of the Studio Introduction workflow.
CalMAN for Business Download Link
CalMAN Home Theater Download Link
CalMAN Studio Download Link
CalMAN 5.5.1 Final - Build: 1964 Released @ 06 July 2015
New Features
Added support for OSEE to function as a pattern generator (CalMAN Ultimate).
Added OSEE file format for cube calibrations within SpectraCal’s Cube Generator (CalMAN Ultimate).
Changes
Changed the default pattern delay setting for Eizo displays.
Added a check box within the source tab for madVR. This button will force the patterns to go into fullscreen mode while CalMAN is taking readings. The window will return to its previous state when the readings are finished. This feature requires madVR version 0.88.14 or higher.
Disabled the "Include Stabilizing Delay for Read All" setting by default.
CalMAN will no longer calculate Contrast Ratio unless both black and white readings have been taken.
Resolved Issues
Resolved issue where deltaE chart target lines might not be displayed once they are enabled.
Resolved issue where Pattern Auto Advance would apply to an automated pattern generator if going from a manual pattern generator to an automatic generator.
Resolved crashes that occurred when CalMAN would not recreate a settings file on startup if it were missing.
Resolved an issue that would occur on the Lumen Radiance (all models). CalMAN would not reset the internal 3D LUT at the start of a cube calibration.
Fixed a typo ColorChecker button on last layout of Studio Introduction workflow.
Download Links
CalMAN 5.5.2 Open Beta - Build: 1966 Released @ 14 July 2015
Release Notes posted from SpectraCAL's Support Team
''So, we've got a new build that makes changes to the Radiance. Specifically we've changed how we connect and how we perform resets to 3D LUTs. This should speed up performance in these areas.
I've worked on this with a Radiance XD, 20xx, and 21xx series models and everything looks good, but we'd really like to get feedback from the field. Let us know how its going for you, if you have any issues, etc.''
Download Links
CalMAN 5.5.2 Open Beta - Build: 1970 Released @ 22 July 2015
Release Notes
Added support for the Panasonic 2015 CR/CX/CZ models. I don't have confirmation on the regions that support this functionality, but it should be all of the regions which were supported before (Us/Canada/EU/NZ/Asia). Japan might also be added, but I don't have confirmation.
Added the ability to add an extra delay when switching in/out of full screen mode for madTPG. This delay applies to both Normal and Exclusive modes. Settings show up on the Source tab. The delay slider is in 1/100 of a second. We're looking into keeping full screen up during series reads, but that is going to have to wait until 5.6.0. This now requires madVR version 0.88.20 or higher.
Known Issues
We've added some extra grayscale points for the isMini, but they aren't quite working right at the moment.
We've added a White OLED edr to the C6, but the file is missing from the installer so its not working at the moment.
CalMAN Eyeglass is currently crashing when opening image files.
Download Links
CalMAN 5.5.2 Open Beta - Build: 1977 Released @ 01 August 2015
Release Notes
The newly added White OLED table for the C6 is now in and functional.
Added SMTPE level points for 1D LUTs on the isMini
Resolved issue that caused CalMAN Eyeglass to crash when loading an image file.
Resolved issue that would cause the Jetis to not work with CalMAN is they were only calibrated 380-780.
Tutorial Basic and Tutorial Advanced workflows have been replaced with a new Home Express workflow. This is designed around MobileForge instead of calibration DVDs. We'd love some feedback on this new workflow.
Added capability for a Brightness and Contrast patterns for MobileForge.
Download Links
CalMAN 5.5.2 Final - Build: 1979 Released @ 05 August 2015
New Features
Added support for 2015 Panasonic models: CR, CX, & CZ
Added a configurable delay when enabling/disabling full screen mode for madTPG. This is configurable under the source tab and is labeled in 1/100 seconds. Requires madVR 0.88.20 or higher.
Added a white OLED table for the C6 meter.
Changes
Improved connection and LUT reset performance with the Lumen Radiance when it is connected for 3D LUTs.
Added SMTPE level points for 1D LUTs for the Fujifilm IS-mini LUT box. (CalMAN Ultimate)
Removed DeltaE field on ICC creation layout for the ‘Monitor - Advanced workflow’.
Home Theater Tutorial workflows have been replaced with the new ‘Home Express workflow’
Renamed Home Theater workflows to follow new naming convention.
Resolved Issues
Resolved issue where CalMAN Eyeglass would crash when opening an image file. (CalMAN Professional & Ultimate)
Resolved an issue with Jeti Specbos 1211 meters if they were calibrated only to visible range. (CalMAN Professional & Ultimate)
Download Links
CalMAN 5.6.0 Open Beta - Build: 2136 Released @ 02 September 2015
Release Notes
Optimized AutoCube algorithms for grayscale performance in general as well as a focus near black.
For those of us performing cube calibrations, we really want to get your feedback on this.
Added Support for the Astro VG series pattern generators (Ultimate, Professional, Expert, Studio, and ColorChecker)
Added madVR support to the Professional license level (Pattern Generator and Display)
Added new FSI models to the drop down box for the FSI Display
Prisma has been added as a drop down selection for format for the SpectraCal Cube Generator
Qinc Prisma has been added as its own entry as a display. This creates a LUT file that can be uploaded to the device using the Prisma's interface. (Ultimate, Professional, Studio, Enthusiast)
Resolved an issue where the Load LUT File button on the 3D LUT DDC Controls screen was not working.
Resolved an issue that would cause hangs/crashes when performing a 3D LUT calibration in PC Levels.
Removed Manual DVDs. Pattern Change Prompts under the default Source option still function as usual.
Removed support for all IR controlled devices except for the SpectraCal DPG line.
Download Links
CalMAN 5.6.0 Open Beta - Build: 2143 Released @ 09 September 2015
Release Notes
Added support for the Murideo pattern generator to the Ultimate, Professional, Expert, Studio, and ColorChecker license levels.
Resolved various errors and crashes when creating a 3D LUT.
Added 25% Only and 50% Only as options for Saturation sweeps.
Added 2pt Grayscale and Dynamic Range layouts to the Quick Analysis workflows.
Added the ability to show 8, 10, or 12 bit levels on the slider bar
Note: For those of you who have been seeing crashes or having issues with 3D LUTs, give it a run on this build and let us know how it goes.
Download Links
CalMAN 5.6.0 Open Beta - Build: 2158 Released @ 22 September 2015
Release Notes
Updated the Quick Analysis workflow to include 2pt Grayscale and Dynamic Range layouts.
Major updates to the HT Enthusiast and SI Professional workflows.
Minor tweaks to the SI Basic and SI Advanced workflows.
Added RGB Triplet support for the QD 804 pattern generator.
Added Drift Compensation*
*The beginnings of Drift Compensation have been in since the first 5.6.0 beta and we've been working on improving the algorithms since.
CalMAN's iRP calibration takes additional measurements to track the drift of the display over the time it is under testing. This allows the measurement data to be corrected for both luminance and chromaticity to produce a final 3D LUT with a higher level of accuracy. This is especially valuable on displays that exhibit image retention.
Download Links
CalMAN 5.6.0 Open Beta - Build: 2166 Released @ 29 September 2015
Release Notes
Not announced yet.
Download Links
CalMAN 5.6.0 RC1 - Build: 2175 Released @ 07 October 2015
Release Notes
New Features
- CalMAN’s built-in pattern generator can now generate Dolby Vision enabled patterns. With Dolby Vision's unique gamut remapping, we also have included gamut targets for both the VIZIO RS65 and RS120 flagship displays. Additional Dolby Vision gamut support will be included as additional displays are made available. (Expert, Professional, Ultimate)
- CalMAN's (IRP) 3D LUT calibration now takes additional measurements to track the drift of the display while a calibration is taking place. This allows the measured data to be corrected for both luminance and chromaticity which produces a final 3D LUT with a higher level of accuracy. This is especially valuable on displays that exhibit image retention. (Ultimate)
- Added support the Astro VG series pattern generators. (Expert, Professional, Ultimate)
- Added support for the Murideo SIX-G pattern generator. (Expert, Professional, Ultimate)
- Added 25% only and 50% only levels as options for Saturation sweeps. (All)
- Added the ability to show 8, 10, or 12 bit levels on the slider bar. (All)
- Added full RGB triplet support for the Quantum Data 804 pattern generator. (Ultimate)
- Added support for Murideo Prisma format found under the SpectraCal Cube Generator. (Ultimate)
- Added the Murideo Prisma as a display option. This creates a LUT file that can be uploaded into the device through the Murideo utility. (Professional, Ultimate)
Changes
- CalMAN now defaults to cd/m2 (Nit) instead of fL (foot lambert) for brightness measurement units. (All)
- Removed Manual DVD support. (All)
- Removed support for all IR controlled devices except for the SpectraCal DPG product line. (All)
- Added new FSI models to the ‘model’ drop down for FSI displays. (Flanders, Ultimate)
- Added support for madVR as both a Pattern Generator and Display. (Professional)
- Updated the following workflows:
- Quick Analysis
- SI Advanced
- SI Basic
- SI Professional
- HT Enthusiast
Resolved Issues
- Resolved an issue where the ‘Load LUT File’ button on the 3D LUT DDC controls was not working. (Ultimate)
​- Resolved an issue that would cause hang-ups/crashes when performing a 3D LUT calibration with PC Levels selected. On some devices an error message would appear stating the points were not supported for the device. (Ultimate)
Download Links
CalMAN 5.6.0 - Build: 2180 Released @ 16 October 2015
Release Notes
New Features
Added support for the Astro VG series pattern generators. (Expert, Professional, Ultimate)
Changes
- Quick Analysis
- SI Advanced
- SI Basic
- SI Professional
- HT Enthusiast
There is now a check box for the Quantum Data 780C to enable HD-SDI output. This option forces the output from the 780C into YCbCr, rather than RGB. With this option checked, you can then set the colorspace to Rec.601, 709, or 2020. (All)
Resolved Issues
​Resolved an issue that would cause hang-ups/crashes when performing a 3D LUT calibration with PC Levels selected. On some devices an error message would appear stating the points were not supported for the device. (Ultimate)
Download Links
CalMAN 5.6.1 Open Beta - Build: 2195 Released @ 11 November 2015
Release Notes
Resolved an issue with the K-10 where CalMAN would use table 0 when selecting tables above 39.
Resolved issue that could cause data grids to not populate with data on some non English version of windows if the data point used a decimal.
Added HDR-10 support for Quantum Data 780 and 804 models (the 804b is currently having issues and this is on the QD side). Note - This may require newer firmware.
Added APL pattern and variable pattern size wupport to the Quantum Data 780 and 804 models.
Added support for the Astro 876/877 model generators which includes HDR-10 support.
Added the new ColorChecker Video patch set.
Fixed the ColorChecker workflow so it is no longer defaulting to a 5600K white point.
ColorChecker workflow has been renamed to CalMAN Color. That name may change again before final release.
Added a ColorChecker layout to the Dolby Vision workflow.
Changed the CIE chart in the Dolby Vision workflow to CIE 1976.
Minor tweaks to the SI Advanced workflow and report.
Added meter positioning layout to HT Enthusiast workflow.
Download Links
CalMAN 5.6.1 Open Beta - Build: 2200 Released @ 19 November 2015
Release Notes
Resolved an issue with the CR-100 and CR-250 meters that could give read errors near black.
Resolved an issue that could cause datagrids to display data in the wrong columns.
Resolved an issue creating 3D LUT files for TVLogic displays using the SpectraCal CalMAN Cube Generator. This issue did not exist when connecting directly to a TVLogic as a display.
CalMAN now requires madVR version 0.89.17 or higher.
Tweaked 3D LUT algorithms to help reduce possible banding.
Added new 1D LUT formats for the SpectraCal Cube Generator. New formats are .txt (Black magic) and .cube (AJA).
Firmware version 2.3 for the AJA LUT box now allows you to select if the deice is set to Full or SMPTE levels. This option is in the AJA Mini Config utility on the LUT page.
On the AutoCal Setup dialog when creating a cube, there are now 2 options for the AJA – LUT box format for Output Cube Size (right under the File Format drop down). You want to select 17 Points 16-235 if you are running older firmware or if you have selected SMPTE in the AJA utility. You want to select 17 Points if you are running the new firmware and you have set the AJA LUT box to Full in its utility. The setting in the AJA LUT box must be made before running the AutoCube calibration.
Download Links
CalMAN 5.6.1 Open Beta - Build: 2201 Released @ 21 November 2015
Release Notes
Fixed an issue with sync on the CR-100 meter that we introduced with the last beta.
Download Links
CalMAN 5.6.1 RC1 - Build: 2207 Released @ 08 December 2015
Release Notes
New Features
Added new 1D LUT formats for the SpectraCal Cube Generator. New formats are .txt (AJA) and .cube (Black Magic). (Studio)
Added HDR-10 support for Quantum Data 780 and 804 pattern generators (no 804b support at this time). This requires firmware version 15092260 or higher. (Studio, ColorMatch)
Added APL pattern and variable pattern size support to the Quantum Data 780 and 804 pattern generators. (Studio, ColorMatch)
Added support for the Astro 876/877 pattern generators which includes HDR-10 support. (Studio, ColorMatch)
Added the new ColorChecker Video patch set released by X-Rite in October. (All)
Added support for the Canon 1D and 3D LUT formats in the CalMAN Cube Generator. (Studio)
Changes
CalMAN 5.6.1 now requires madVR version 0.89.17 or higher. (Studio)
The ‘ColorChecker’ workflow and license level have been renamed to ‘ColorMatch’. (Studio, Studio Lite, Studio Express)
Improved 3D LUT algorithms to help reduce possible banding. (Studio, Studio Lite, Studio Express)
Added additional data point options for 1D LUTs in the CalMAN Cube Generator. (Studio)
Changed the default delta E threshold for Cuts and Gains AutoCal from 1.0 to 0.5. (Studio, Studio Lite, Studio Express)
Minor adjustments made to the SI Advanced workflow. (Studio)
Minor tweaks made to the Monitor Advanced workflow. (Studio, Studio Lite)
Added a ColorChecker layout to the Dolby Vision workflow. (Studio)
Updated the Monitor Direct (EIZO/HP) workflow. (Studio, Studio Lite)
Resolved Issues
Resolved an issue with the Klein K-10 meter where CalMAN would use table 0 when selecting tables above 39. (Studio, Studio Lite, Studio Express, ColorMatch)
Resolved an issue that could cause data grids to not populate on some non-English versions of Windows if the data point contained a decimal. (All)
Resolved read errors with the CR-100 and CR-250 meters that could be caused when reading near black. (Studio, Studio Lite, ColorMatch)
Resolved an issue creating 3D LUT files for TVLogic displays using the SpectraCal CalMAN Cube Generator. This issue did not exist when connecting directly to a TVLogic as a display. (Studio)
Resolved read error with the Rev. B X-Rite i1 Display Pro meter when reading near black. (Studio, Studio Express, Studio Lite, ColorMatch)
The ColorMatch workflow now defaults to D65 white point and not to a 5600K white point. (Studio, Studio Lite, Studio Express)
Download Links
CalMAN 5.6.1 Open Beta - Build: 2218 Released @ 24 December 2015
Release Notes
CalMAN now requires .NET 4.6.
Some workflow tweaks to SI Advanced, SI Professional, Color Cube, and Dolby Vision workflows.
Added support for 1D LUT for the Prisma. Supports either .csv or .cube file formats.
Resolved an issue for near black banding as well as some overall accuracy improvements for 3D LUTs.
Added an exception handler for the CR-100 meter.
Download Links
CalMAN 5.6.1 Final - Build: 2238 Released @ 11 January 2016
Release Notes
New Features
Added new 1D LUT formats for the SpectraCal Cube Generator. New formats are .txt (AJA) and .cube (Black Magic). (Ultimate)
Added HDR-10 support for Quantum Data 780 and 804 pattern generators (no 804b support at this time). This requires firmware version 15092260 or higher. (Expert, Professional, Ultimate)
Added APL pattern and variable pattern size support to the Quantum Data 780 and 804 pattern generators. (Expert, Professional, Ultimate)
Added support for the Astro 876/877 pattern generators which includes HDR-10 support. (Expert, Professional, Ultimate)
Added support for the NEC OEM X-Rite i1 Display Pro meter. (Ultimate)
Added support of 1D LUTs for the Murideo Prisma. Supports either .csv or .cube file formats. (Ultimate)
Changes
CalMAN now requires .NET 4.6 or higher.
CalMAN 5.6.1 now requires madVR version 0.89.17 or higher. (Professional, Ultimate)
The ‘ColorChecker’ workflow and license level have been renamed to ‘ColorMatch’. (Expert, Professional, Ultimate)
Improved 3D LUT algorithms to help reduce possible banding. (Ultimate)
Added additional data point options for 1D LUTs in the CalMAN Cube Generator. (Ultimate)
Changed the default delta E threshold for Cuts and Gains AutoCal from 1.0 to 0.5. (Expert, Professional, Ultimate)
Minor adjustments made to the SI Advanced workflow. (Expert, Professional, Ultimate)
Minor tweaks made to the Monitor Advanced workflow. (Expert, Professional, Ultimate)
Added a ColorChecker layout to the Dolby Vision workflow. (Ultimate)
Updated the Monitor Direct (EIZO/HP) workflow. (Expert, Professional, Ultimate)
Updated the Color Cube (3D LUT) workflow. (Ultimate)
Updated the Dolby Vision workflow. (Ultimate)
Updated 2-point RGB calibration datapoint preset. This selection will now default to match the layout settings. (Ultimate)
Added a 10%/Peak White dataset. (All)
Resolved Issues
Resolved an issue with the Klein K-10 meter where CalMAN would use table 0 when selecting tables above 39. (Expert, Professional, Ultimate)
Resolved read errors with the CR-100 and CR-250 meters that could be caused when reading near black. (Expert, Professional, Ultimate)
Resolved an issue creating 3D LUT files for TVLogic displays using the SpectraCal CalMAN Cube Generator. This issue did not exist when connecting directly to a TVLogic as a display. (Ultimate)
Resolved read error with the Rev. B X-Rite i1 Display Pro meter when reading near black. (Expert, Professional, Ultimate)
The ColorMatch workflow now defaults to D65 white point and not to a 5600K white point. (Expert, Professional, Ultimate)
Resolved an issue for near black banding as well as overall accuracy improvements for 3D LUTs. (Expert, Professional, Ultimate)
Added an exception handler for CR-100 meter. (Expert, Professional, Ultimate)
Resolved an issue that could cause crashing with Dolby Vision patterns. (Expert, Professional, Ultimate)
Download Links
CalMAN 5.6.1b - Build: 2241 Released @ 06 February 2016
Changes
Added the ST2084 Gamma formula to the Expert and Professional license levels.
Modified the logo on the Color Cube (3D LUT) Report to a CalMAN logo. (Studio, Expert, Professional, Ultimate)
Fixed an error in the SI Advanced workflow on the Grayscale &Gamma Multipoint Adjust layout. The AutoCal button no longer resets a 3D LUT if it exists. (Studio, Expert, Professional, Ultimate)
Download Links
41 - 60 of 77 Posts
