1 - 9 of 9 Posts
Speaker Cable Flat 4 core: I'm at a loss to buy the simple version for splicing.
Newbie here, just looking for friendly advice.
I live in SD, Ca. I've looked at Radio Shack and Fry's with no luck.
This is a similar cable. The one I am using had a thicker black rubber covering.
I read in sound on sound that a bunch of hi-fi enthusiasts in a blind test couldn't tell the the difference between some of the most expensive cable and some soldered coat hangers :heehee:
Parts express has it also Here
Amazon came up with these also
Discussion Starter #7
Thanks for the post. If I went to a 2 core cable, how would I know witch two are LL and the other RR?
I would just write on the ends with a black felt.
1 - 9 of 9 Posts
