1 - 9 of 9 Posts
Hi, I would appreciate your opinions about this work. Your comments are important...
Thank You
Best Regards
Max
Nice job, was this a DIY project? Looks like you put a lot of effort into the room. How did you decide on the room treatments?
Hi, thank you very much!!! This is a Home Theater, and the Screen is 170 inches stewart THX studiotek.
The system is JBL Synthesis Two, and the projector SONY Qualia 004. I am really the home theater design, I am too make all project, and the acoustics, I make all panels. The room is a THX certified.
Well thank you best regards!!!
1 - 9 of 9 Posts
