Furman IT-Reference 15i Power Conditioner Review: Discussion Thread
For the Full Review: Click Here!
MSRP: $2000
Value: :4stars:
Fit & Finish: :5stars:
Home Theater Performance: :4.5stars:
Music Performance: :4.5stars:
Overall: :4.5stars:
Summary: Given the results of my time spent with the IT-Reference 15i, I can safely say that the product does what it does very well. It filters line level hum, removes noise, and keeps your equipment safe from surges. It didn't add "air", tighten up the bass, or even change the sound of my system as far as I am aware, but this isn't a failing in my opinion.
This may be the one situation in which I can heartily recommend a product that will not do a thing to improve the sound of your equipment directly. Rather, this piece of gear will allow you to hear what your equipment is capable of. A lower noise floor allows greater dynamic range, just as the absence of a high frequency buzz will improve the treble. It's not about improving the gear, it's about getting the electromagnetic junk out of the way and letting the music play, and in this case Furman has done a spectacular job at doing just that. Highly Recommended.
MSRP: $2000
Value: :4stars:
Overall: :4.5stars:
