Re: Gain Structure for Home Theater: Getting the Most from Pro Audio Equipment in Your System
Hi
I'm just a little confused here.
The "post-pre amp signal boosting is not recommended" statement seems diametrically opposed to your Figure 2 where 3dB is added between the Notch Filter and again before the Limiter, but I don't see anything on that graphic labeled "preamp" hence my confusion.
Also
When I look at Figure 1 I see a System Dynamic Range (SDR) of 72dB and the Figure 2, after alignment, shows an SDR of 90 dB. Then in the rest of the article you make the case that the original 72dB was enough and in fact loss of an additional 6 or 12 dB would not be an issue. Sorry I think I missed something.
Hi
Also
